Selecting a USRP Device
Revision as of 13:41, 1 May 2016 by Ettus (Talk | contribs)
AN-881
Date Author Details
2016-05-01 Neel Pandeya
Nate Temple
Initial creation
This AN explores the USRP family at a high level, compares devices across several primary features, and walks the reader through the process of selecting a particular device for the their application.
Reference: https://www.ettus.com/content/files/kb/application_note_selecting_a_usrp.pdf
USRP Product Selector
https://www.ettus.com/usrp-product-selector
This guide is provided by Ettus Research to help users select the most appropriate Universal Software Radio Peripheral (USRP™) for their specific application. In order to make the selection process as straightforward as possible, a table showing various features is provided as a basis for the selection process.
Understanding DSP Fundamentals
If you are new to the USRP family of products, software defined radio, or digital signal processing in general, it may be useful to perform some simulation of the signals you wish to manipulate before selecting USRP hardware. Simulating signals and algorithms in software frameworks such as GNU Radio or LabVIEW will ensure a proper understanding of various concepts, such as Nyquist theorem, ADC/DAC and limitations, for example. Understanding the basics of signal theory and digital signal processing is the first step towards understanding how to make the best use of an appropriate USRP model. This link provides access to several resources that may be helpful in understanding the basics.
http://gnuradio.org/redmine/projects/gnuradio/wiki/SuggestedReading
Common Applications
Table 1 shows USRP/daughterboard combinations commonly used in various application areas. While Table 1 can serve as a starting point for selecting a USRP device, Ettus Research recommends new users evaluate their application requirements against the specifications of the USRP devices. sections of this document will assist in the selection process.
Application Area Common USRP Model Common Daughterboard
PHY/MAC Research N200/N210 X300/X310 WBX/SBX/UBX/CBX
Radar Research X300/X310 SBX/UBX
OpenBTS B200/B210 X300/X310 E310/E312 N200/N210 WBX/SBX/UBX/CBX
Amarisoft LTE N200/N210 X300/X310 WBX/SBX/UBX/CBX
Education B200/B210 X300/X310 E310/E312 N200/N210 WBX/SBX/CBX/UBX
HF Communications N200/N210 X300/X310 LFRX/LFTX
Signals Intelligence X300/X310 SBX/UBX
Distributed RF Sensors E310/E312 N/A
Mobile Radios E310/E312 N/A
MIMO X300/X310 SBX/UBX
Phased Array X300/X310 SBX/UBX
FPGA Computing X310 WBX/SBX/UBX/CBX
Embedded Computing E310/E312 N/A
Small Form Factor (SWaP) B200mini/B205mini E310/E312 N/A
Table 1 - Recommended USRP Selection for Various Application Areas
USRP Device Characteristics
Table 2 shows the key characteristics of all USRP models available from Ettus Research. The table is useful for determining the interface type, bandwidth capabilities, and synchronization mechanisms specified for each USRP model. You can use this information, and the requirements for the application in question, to select a USRP radio.
USRP Model Interface Total Host BW (MSPS 16b/8b) Daughterboard Slots ADC Resolution (bits) ADC Rate (MSPS) DAC Resolution (bits) DAC Rate (MSPS) MIMO Capable Internal GPS Disciplined Oscillator (Optional) 1 PPS/Ref Inputs
N210 GigE 50/100 1 14 100 16 400 Yes Yes Yes
N200 GigE 50/100 1 14 100 16 400 Yes Yes Yes
B100 USB 2.0 8/16 1 12 64 14 128 No No No
USRP1 USB 2.0 8/* 2 12 64 14 128 Yes No No
E100 Embedded 8/16 1 12 64 14 128 No Yes Yes
E110 Embedded 8/16 1 12 64 14 128 No Yes Yes
B200mini USB 3.0 61.44 N/A 12 61.44 12 61.44 No No Yes
B205mini USB 3.0 61.44 N/A 12 61.44 12 61.44 No No Yes
B200 USB 3.0 61.44 N/A 12 61.44 12 61.44 No Yes Yes
B210 USB 3.0 61.44 N/A 12 61.44 12 61.44 Yes Yes Yes
X300 USB 3.0
1 GigE
10 GigE
PCIe
200 2 14 200 16 800 Yes Yes Yes
X310 USB 3.0
1 GigE
10 GigE
PCIe
E310 Embedded 61.44 N/A 12 61.44 12 61.44 Yes No Yes
E312 Embedded 61.44 N/A 12 61.44 12 61.44 Yes No Yes
Table 2 - USRP Characteristics by Model
The following sections cover frequently asked questions in choosing a USRP device that’s right for your application.
Do I want to perform processing on a host PC, or operate the USRP device in a standalone fashion? This is an obvious differentiator of the USRP Embedded Series. If you need the USRP to operate a USRP radio without a host PC, the USRP E310/E312 is the most appropriate. The USRP E310/E312 is ideal for applications that might require mobile transceivers or distributed RF sensors. Unless the user has a clear requirement for embedded operation, Ettus Research recommends the USRP N200, N210, B200, B210, X300 or X310. Developing with a host-based platform typically involves less risk and will require less effort to optimize various pieces of the software radio.
In many cases it may be easier to develop with a USRP B200/B210 or USRP N200/N210, then port the code to the USRP E310/E312. The UHD (USRP Hardware Driver) enables this portability. You must also consider the different processing capabilities of the host machine and ARM processor used on the USRP E310/E312.
Do I Need Synchronization and/or MIMO Capability? Table 3 summarizes the synchronization features of each USRP device. Table 4 shows recommended solutions for MIMO systems of various sizes.
If you need MIMO capability for your application, Ettus Research recommends the USRP N200/N210 or USRP X300/X310. These units can be synchronized by providing a common time and frequency reference. Two USRP N200/N210s can be synchronized for MIMO operation with an Ettus Research MIMO cable. Alternatively, external 10 MHz reference and 1 PPS signals can be distributed to multiple USRP radios. With proper consideration for interface issues, it is possible to create MIMO system of arbitrary size with the USRP N200/N210 or USRP X300/X310.
The USRP B210 can serve a 2x2 MIMO capability because it has two integrated RF channels. However, the available bandwidth is limited dependent upon the USB controller, and selected MIMO configuration. Additional details of each configuration can be found in the USRP B200 and B210 - USB 3.0 Streaming Rate Benchmarks application note. However, the USB 3.0 interface limits the bandwidth per channel. The combined throughput of all transmit and receive channels cannot exceed 8 MS/s.
In most cases the USRP B100 and E100/E110 are not appropriate for applications requiring a MIMO system. However, if you intend to operate at low frequencies it may be possible to use the LFRX/TX and BasicRX/TX, which can provide two channels on each daughterboard. If only receive capability is needed, the TVRX2 can meet the requirements for multiple-input capability in all USRP devices.
USRP Model BW Capability (MSPS w/ 16-bit) MIMO Capable Ext Ref. Input 1 PPS Input Internal GPS Disiplined Oscillator (Optional) Plug and Play MIMO
USRP1 8 X
N200 25 X X X X X
N210 25 X X X X X
E100 4 X X X
E110 4 X X X
B100 8 X X
B200mini 61.44 X X
B205mini 61.44 X X
B200 61.44 X X X
B210 61.44 X X X X X
X300 200 X X X X X
X310 200 X X X X X
E310 61.44 X X X X
E312 61.44 X X X X
Table 3 - Synchronization Capability of USRP Devices
USRP Model 2 x 2 MIMO 4 x 4 MIMO M x N MIMO
USRP1 2x Daughterboard Not Recommended Not Recommended
N200/N210 MIMO Cable MIMO Cable + External External
E100/E110 Not Recommended Not Recommended Not Recommended
B100 Not Recommended Not Recommended Not Recommended
B200mini Not Recommended Not Recommended Not Recommended
B205mini Not Recommended Not Recommended Not Recommended
B200 Not Recommended Not Recommended Not Recommended
B210 Integrated Not Recommended Not Recommended
X300 2x Daughterboard OctoClock OctoClock
X310 2x Daughterboard OctoClock OctoClock
E310 Integrated Not Recommended Not Recommended
E312 Integrated Not Recommended Not Recommended
Table 4 - Recommended Models for MIMO Systems
What Are My Bandwidth Requirements? Many Bandwidth requirements can also be used to narrow down the USRP selection. As seen in the table, the USRP N200/N210 is capable of streaming up to 50 MS/s in each direction in 8-bit mode, and 25 MS/s in 16-bit mode. The USRP B200 is capable of streaming up to 61.44MS/s total in 16-bit or 8-bit modes, respectively. The USRP1 only operates in 16-bit modes, and is limited to 8 MS/s applications, such as OpenBTS, only utilizing a few hundred kHz of instantaneous BW. In these cases, the BW capability of the USRP1 and USRP B100 are more than adequate.
However, if there is interest in transmit and/or receiving larger bandwidth signals such as 802.11, the USRP N200/N210 would be more appropriate. Note these limitations are based on the data throughputs provided by the corresponding interfaces. It is important to consider the performance of the processing platform, and the computational intensity of the application. The constraints of the processing platform are independent of the full capability of the Ettus Research USRP radio and UHD.
The USRP E310/E312 FPGA interface provides a maximum throughput of [ADD STAT] 40 MB/s. This bandwidth can be used distributed across transmit and receive sample transfer. At 4 bytes/sample, this provides for a total of [ADD STAT] 10 MS/s. Note this does not guarantee that the embedded processor will be able to process that many samples. Additional care must be taken to understand the processing limitations and best DSP practices for optimum performance.
What interface do I prefer to work with?
Assuming you have narrowed the viable devices down based on bandwidth, MIMO and channel count requirements, it is possible to select a USRP device based on the interface.
In general, USB 3.0 ports are more plentiful on computers. This makes the USRP B200/B210 and USRP1 slightly more usable at short ranges. The USRP N200/N210 requires a Gigabit Ethernet port and a PC typically only provides one such port. If internet access is required, the user will also need to plan for an additional network adaptor.
The Gigabit Ethernet interface of the USRP N200/N210 can operate over significantly longer ranges. This makes it possible to operate the USRP radio it more remote locations further from the host computer. The GigE interface can be accessed via a Gigabit Ethernet switch, allowing access to multiple devices. However, Ettus Research recommends a homogeneous network without other devices, such as network routers attached.
Will I develop custom IP for the USRP device’s FPGA? While most users deploy their USRP devices in a stock configuration, many others customize the FPGA with their own functionality. For example, you may want to offload modulation, demodulation, or other PHY/ MAC operations to the USRP radio. This reduces host processing requirements, and may allow data reduction before passing data over the host interface. A summary of the FPGAs used on each USRP model are shown in Table 5.
N210 N200 E110 E100 USRP1 B100 B200mini B205mini B200 B210 X300 X310 E310 E312
FPGA Vendor Xilinx Xilinx Xilinx Xilinx Altera Xilinx
FPGA Series Spartan 3A DSP Spartan 3A DSP Spartan 3A DSP Spartan 3A DSP Cyclone Spartan 3A
FPGA Part Number XC3SD3400A XC3SD1800A XC3SD3400A XC3SD1800A XC3S1400A
System Gates 3200k 1800k 3200k 1800k 1400k
Logic Elements - - - - 12000 -
Logic Cells 53714 37440 53714 37440 - 25344
Slices 23872 16640 23872 16640 - 11264
DSP48's 126 84 126 84 0 0
BRAM 373k 260k 373k 260k 234k 576k
DCM's 8 8 8 8 2 8
Free Tools? No Yes No Yes Yes Yes
Table 5 - FPGA Resources
The USRP N200 and USRP N210 are great, generic platforms to experiment with FPGA development. However, the important difference between these two is the FPGA size, and requirements for Xilinx development tools. The USRP N200 includes a Xilinx Spartan XC3SD1800A FPGA. This FPGA is optimized for DSP capability, and the logic can be modified with free Xilinx ISE tools. The USRP N210 includes a Xilinx Spartan XC3D3400A FPGA. This FPGA provides nearly twice the resources, but requires a licensed seat of the Xilinx development tools for development. The USRP E100/110 use the same, respective FPGA sizes as the USRP N200/N210.
The USRP B100 provides a cost-optimized Spartan 3A-1400 FPGA. This can also be modified by the free version of Xilinx tools. The USRP B100 FPGA design does not contain many unused resources.
Do I need flexible sample clock frequencies? Some applications may benefit from a flexible sample clock frequency. The USRP E100/110 and USRP B100 both include a flexible frequency clocking solution. This flexibility allows ideal sample clock frequencies to be used for various communications standards. For example, the GSM implementations commonly use a 52 MHz sample clock.
Do I want or need a rack-mountable solution? Generally speaking, the selection of the USRP is based on performance requirements of the electrical components. However, the convenience of a rack-mounted solution may be an attractive feature that drives your decision. The USRP B100, E100/E110, and N200/N210 can all be mounted in the Ettus Research 3U rack chassis. Up to four USRP devices can be mounted in the chassis. Note there is no off- the-shelf rack mounting solution for the USRP1 device.
Will my requirements become more demanding as I learn more about the USRP and RF systems? One final thing to consider is how your requirements will change over time. While a lower-cost USRP device, such as the USRP B100, may meet your immediate requirements, it is possible that the USRP N200/N210 would be a more appropriate platform as you continue to develop more advanced RF systems. Key improvements to note in the higher-end USRP N200/N210 is the increased bandwidth, increased dynamic range, and MIMO capability.
Fortunately, UHD allows the user to develop a single application compatible with all USRP models. Within certain limitations, the code you develop to work on a USRP B100 will generally work on a USRP N200/N210. You must still consider variables such as sample rate, host interface bandwidth, and synchronization features to ensure compatibility.
Conclusion
This application note presents the functional specifications of each USRP device sold by Ettus Research. The data from this document can be used to make an educated selection of the most appropriate USRP device for a particular user or application. If you have any additional questions, do not hesitate to contact us at sales@ettus.com.
