Getting Started with UHD and C++
Introduction
This Application Note will walk through building a basic C++ program with UHD. This program will initialize, configure the USRP device, set the sample rate, frequency, gain, bandwidth, and select the antenna.
Example code:
#include <uhd/utils/thread_priority.hpp> #include <uhd/utils/safe_main.hpp> #include <uhd/usrp/multi_usrp.hpp> #include <uhd/exception.hpp> #include <uhd/types/tune_request.hpp> #include <boost/program_options.hpp> #include <boost/format.hpp> #include <boost/thread.hpp> #include <iostream> int UHD_SAFE_MAIN(int argc, char *argv[]) { uhd::set_thread_priority_safe(); std::string device_args("addr=192.168.10.2"); std::string subdev("A:0"); std::string ant("TX/RX"); std::string ref("internal"); double rate(1e6); double freq(915e6); double gain(10); double bw(1e6); //create a usrp device std::cout << std::endl; std::cout << boost::format("Creating the usrp device with: %s...") % device_args << std::endl; uhd::usrp::multi_usrp::sptr usrp = uhd::usrp::multi_usrp::make(device_args); // Lock mboard clocks std::cout << boost::format("Lock mboard clocks: %f") % ref << std::endl; usrp->set_clock_source(ref); //always select the subdevice first, the channel mapping affects the other settings std::cout << boost::format("subdev set to: %f") % subdev << std::endl; usrp->set_rx_subdev_spec(subdev); std::cout << boost::format("Using Device: %s") % usrp->get_pp_string() << std::endl; //set the sample rate if (rate <= 0.0) { std::cerr << "Please specify a valid sample rate" << std::endl; return ~0; } // set sample rate std::cout << boost::format("Setting RX Rate: %f Msps...") % (rate / 1e6) << std::endl; usrp->set_rx_rate(rate); std::cout << boost::format("Actual RX Rate: %f Msps...") % (usrp->get_rx_rate() / 1e6) << std::endl << std::endl; // set freq std::cout << boost::format("Setting RX Freq: %f MHz...") % (freq / 1e6) << std::endl; uhd::tune_request_t tune_request(freq); usrp->set_rx_freq(tune_request); std::cout << boost::format("Actual RX Freq: %f MHz...") % (usrp->get_rx_freq() / 1e6) << std::endl << std::endl; // set the rf gain std::cout << boost::format("Setting RX Gain: %f dB...") % gain << std::endl; usrp->set_rx_gain(gain); std::cout << boost::format("Actual RX Gain: %f dB...") % usrp->get_rx_gain() << std::endl << std::endl; // set the IF filter bandwidth std::cout << boost::format("Setting RX Bandwidth: %f MHz...") % (bw / 1e6) << std::endl; usrp->set_rx_bandwidth(bw); std::cout << boost::format("Actual RX Bandwidth: %f MHz...") % (usrp->get_rx_bandwidth() / 1e6) << std::endl << std::endl; // set the antenna std::cout << boost::format("Setting RX Antenna: %s") % ant << std::endl; usrp->set_rx_antenna(ant); std::cout << boost::format("Actual RX Antenna: %s") % usrp->get_rx_antenna() << std::endl << std::endl; return EXIT_SUCCESS; }
Use the uhd/host/examples/init_usrp/CMakeLists.txt file as template - Add the names of your C++ source files to the add_executable(...) section - Put both modified CMakeLists.txt file and C++ file into an empty folder - Create a “build” folder and invoke CMake the usual way:
mkdir build cd build cmake ../ make -j4
