B200/B210/B200mini/B205mini
B200
- Xilinx Spartan 6 XC6SLX75 FPGA
- Analog Devices AD9364 RFIC direct-conversion transceiver
- Frequency range: 70 MHz - 6 GHz
- Up to 56 MHz of instantaneous bandwidth
- Full duplex, SISO (1 Tx & 1 Rx)
- Fast and convenient bus-powered USB 3.0 connectivity
- Optional Board Mounted GPSDO
B210
- Xilinx Spartan 6 XC6SLX150 FPGA
- Analog Devices AD9361 RFIC direct-conversion transceiver
- Up to 56 MHz of instantaneous bandwidth (61.44MS/s quadrature)
- Full duplex, MIMO (2 Tx & 2 Rx)
B200mini
- Xilinx Spartan-6 XC6SLX75 FPGA
B200mini-i
- Industrial-grade Xilinx Spartan-6 XC6SLX75 FPGA
B205mini-i
- Industrial-grade Xilinx Spartan-6 XC6SLX150 FPGA
RF Performance
- Power Output >10dBm
- IIP3 (@ typ NF) -20dBm
- Typical Noise Figure <8dB
Physical Specifications
Dimensions
- B200mini/B205mini 5.0 x 8.4 cm
- B200/B210 9.7 x 15.5 x 1.5 cm
Environmental Specifications
- B200mini 0-40 °C
- B200mini-i 0-45 °C
- B205mini-i 0-45 °C
- B200 0-40 °C
- B210 0-40 °C
B200mini
B210
Datasheets
- Transceiver - Analog Devices AD9364
- Transceiver - Analog Devices AD9361
- FPGA - XC6SLX75 / XC6SLX150
- VXTCXO - B200mini VXTCXO
- GPSDO - M9107
- Frequency Synthesizer - ADF4001
- FX3: SuperSpeed USB Controller - CYUSB3014
- Antenna Switch - SKY13317
- Balun - BD3150L50100A00
- Amplifier - PGA−102+
Mechanical Info
Weight
- B200mini 24.0 g
- B200/B210 350 g
Drawings
- B200mini Media:B200mini_drawing.png
- B200 [ ADD ]
- B210 [ ADD ]
Enclosures
- Full Steel Enclosure
- Compatible with green USRP B200 and B210 devices (revision 6 or later)
- Front and rear K-Slots for anti-theft protection
FPGA
- Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.3
B200mini
Slice Logic Utilization | |||||
Used | Total | Percent | |||
Number of Slice Registers | 15949 | 93296 | 17% | ||
Number of Slice LUTs | 19963 | 46648 | 42% | ||
Number used as Logic | 16140 | 46648 | 34% | ||
Number used as Memory | 3823 | 11072 | 34% | ||
Number used as RAM | 972 | ||||
Number used as SRL | 2851 | ||||
Slice Logic Distribution | |||||
Number with an unused Flip Flop | 7910 | 23859 | 33% | ||
Number with an unused LUT | 3896 | 23859 | 16% | ||
Number of fully used LUT-FF pairs | 12053 | 23859 | 50% | ||
Number of LUT Flip Flop pairs used | 23859 | ||||
Number of unique control sets | 429 | ||||
IO Utilization | |||||
Number of bonded IOBs | 114 | 328 | 34% | ||
IOB Flip Flops/Latches | 147 | ||||
Number of IOs | 123 | ||||
Specific Feature Utilization | |||||
Number of Block RAM/FIFO | 110 | 172 | 63% | ||
Number of BUFG/BUFGCTRLs | 6 | 16 | 37% | ||
Number of DSP48A1s | 76 | 132 | 57% | ||
Number of PLL_ADVs | 1 | 6 | 16% | ||
Number using Block RAM only | 110 |
B200
Number of Slice Registers | 15781 | 93296 | 16% | ||
Number of Slice LUTs | 19987 | 46648 | 42% | ||
Number used as Logic | 15983 | 46648 | 34% | ||
Number used as Memory | 4004 | 11072 | 36% | ||
Number used as SRL | 3032 |
Number with an unused Flip Flop | 8281 | 24062 | 34% | ||
Number with an unused LUT | 4075 | 24062 | 16% | ||
Number of fully used LUT-FF pairs | 11706 | 24062 | 48% | ||
Number of LUT Flip Flop pairs used | 24062 | ||||
Number of unique control sets | 434 |
Number of bonded IOBs | 155 | 280 | 55% | ||
IOB Flip Flops/Latches | 124 | ||||
Number of IOs | 172 |
Number of Block RAM/FIFO | 144 | 172 | 83% | ||
Number of BUFG/BUFGCTRLs | 3 | 16 | 25% | ||
Number using Block RAM only | 144 |
B210
Number of Slice Registers | 29310 | 184304 | 15% | ||
Number of Slice LUTs | 36486 | 92152 | 39% | ||
Number used as Logic | 29279 | 92152 | 31% | ||
Number used as Memory | 7207 | 21680 | 33% | ||
Number used as RAM | 1752 | ||||
Number used as SRL | 5455 |
Number with an unused Flip Flop | 14325 | 43635 | 32% | ||
Number with an unused LUT | 7149 | 43635 | 16% | ||
Number of fully used LUT-FF pairs | 22161 | 43635 | 50% | ||
Number of LUT Flip Flop pairs used | 43635 | ||||
Number of unique control sets | 723 |
Number of bonded IOBs | 163 | 338 | 48% | ||
IOB Flip Flops/Latches | 148 | ||||
Number of IOs | 180 |
Number of Block RAM/FIFO | 186 | 268 | 69% | ||
Number of BUFG/BUFGCTRLs | 4 | 16 | 25% | ||
Number of DSP48A1s | 152 | 180 | 84% | ||
Number using Block RAM only | 186 |
Interfaces and Connectivity
B200/B210/B200mini - USB 3.0
Downloads
Application Notes
FAQ
This is a list of frequently asked questions on the USRP B200/B210/B200mini. If you have questions that are not answered in this document, please contact us - info@ettus.com.
5 Msps | 15.36 Msps | 30.72 Msps | 56 Msps | 61.44 Msps | |
1 RX | 1.92 | 2.112 | 2.184 | 2.508 | |
2 RX | 2.148 | 2.436 | 2.508 | 2.64 | |
1 TX | 2.184 | 2.34 | 2.352 | 2.22 | |
2 TX | 2.76 | 2.88 | 2.904 | 2.64 | |
Full Duplex (1x1) | 2.508 | 2.736 | 2.796 | 3.168 | |
2x2 MIMO | 3.252 | 3.588 | 3.672 | 4.11 | 4.092 |
