UBX
Revision as of 16:01, 27 April 2016 by Ettus (Talk | contribs) (Environmental Specifications)
The UBX daughterboard is a full-duplex wideband transceiver that covers frequencies from 10 MHz to 6 GHz. Coherent and phase-aligned operation across multiple UBX daughterboards on USRP X Series motherboards enables users to explore MIMO and direction finding applications. The UBX daughterboard works interchangeably with other USRP daughterboards and is supported by the USRP Hardware Driver™ (UHD) software API for seamless integration into existing applications.
  • RF shielding
  • Full duplex operation with independent TX and RX frequencies
  • Synthesizer synchronization for applications requiring coherent or phase-aligned operation, supported on USRP X Series motherboards
  • Frequency Range: 10 MHz - 6 GHz
  • Versions: 40MHz / 160MHz
  • Power Output: 7 - 20dBm
  • Noise Figure: <10dB
Physical Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
  • 0-40 °C
USRP Compatibility
UBX-40
  • N or X Series
UBX-160
  • X Series only
UBX
UBX Schematics
Datasheets
MAX2871
ADL5375-05
LFCN-2250+
LTC5510
LFCN-490+
HMC624LP4E
NBB-400
PHA-1+
ADA4927-2
ADL5380
MGA-62563
LFCN-1700+
VMMK-3603
LFCN-2600+
855916
LTC5510
LFCN-2600+
TCM1-63AX+
ADA4927-2
AD8591
ADL5380
ZXTC2062E6
NFA21SL
HMC624ALP4E
LFCN-800+
ADP7104-3.3
ADL5375-05
LTC5510
24LC024
ADP7104-5.0
ZXTC2062E6
Mechanical Info (size, weight, drawings)
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Interfaces and Connectivity
Performance Data
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
