SBX
[hide]Device Overview
- Frequency Range: 400MHz - 4.4GHz
- Versions: 40MHz / 120MHz
- Power Output: 100mW
Physical Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Environmental Specifications
- 0-40 °C
USRP Compatibility
SBX-40
- N or X Series
SBX-120
- X Series only
SBX
Datasheets
Mechanical Info (size, weight, drawings)
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Interfaces and Connectivity
