UBX
- 1 Device Overview
- 2 Key Features
- 3 RF Specifications
- 4 Physical Specifications
- 5 Environmental Specifications
- 6 USRP Compatibility
- 7 Schematics
- 8 Datasheets
- 9 Mechanical Info (size, weight, drawings)
- 10 Interfaces and Connectivity
- 11 Certifications
- 12 Important Notes
- 13 Performance Data
- 14 Downloads
The UBX daughterboard is a full-duplex wideband transceiver that covers frequencies from 10 MHz to 6 GHz. Coherent and phase-aligned operation across multiple UBX daughterboards on USRP X Series motherboards enables users to explore MIMO and direction finding applications. The UBX daughterboard works interchangeably with other USRP daughterboards and is supported by the USRP Hardware Driver™ (UHD) software API for seamless integration into existing applications.
The UBX is capable of phase coherent operation, and therefor is suitable for MIMO and Phased Array applications.
- RF shielding
- Full duplex operation with independent TX and RX frequencies
- Synthesizer synchronization for applications requiring coherent or phase-aligned operation, supported on USRP X Series motherboards only
- Frequency Range: 10 MHz - 6 GHz
- Versions: 40MHz / 160MHz
- Noise Figure
- 10 - 20 MHz: 3 - 4 dB
- 20 - 500 MHz: 2 - 3 dB
- 0.5 - 1.5 GHz: 2 - 4 dB
- 1.5 - 4 GHz: 4 - 5 dB
- 4 - 6 GHz: 5-7 dB
- RX IIP3 (Max)*
- 10** - 35 MHz: 4 - 10 dBm
- 35 - 500 MHz: 10 - 12 dBm
- 0.5 - 1.5 GHz: 8 - 13 dBm
- 1.5 - 6 GHz: 8 - 9 dBm
- RX IQ Imbalance
- 10 MHz - 6 GHz: < -30dBc
- TX Power (Max)
- 10 MHz - 3.5 GHz: > 20 dBm
- 3.5 - 4 GHz: 18 - 20 dBm
- 4 - 5 GHz: 13 - 18 dBm
- 5 - 6 GHz: 7 - 13 dBm
- TX OIP3
- 10 - 500 MHz: > 40 dBm
- 0.5 - 3 GHz: > 36 dBm
- 3 - 5 GHz: > 30 dBm
- 5 - 6 GHz: > 26 dBm
- TX IQ Imbalance
- 10 MHz - 6 GHz: < -30 dBc
Note: * Noise Figure < 10 dB
Note: ** High Gain at 10 MHz
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
- 0-40 °C
USRP Compatibility
UBX-40
- N or X Series
UBX-160
- X Series only
UBX
Datasheets
NFA21SL
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Important Notes
- A larger 24W (6V, 4A) power supply is required when using a UBX-40 daughterboard and integrated GPS Disciplined Oscillator accessory together in a USRP2, USRP N200, or USRP N210 device.
- The UBX-160 transmitter path has 160 MHz of bandwidth throughout the full frequency range of the device; the receiver path has 84 MHz of bandwidth for center frequencies from 10 MHz to 500 MHz.
