Revision as of 13:54, 29 April 2016 by Ettus (Talk | contribs) (RF Specifications)
B200
B210
B200mini
B200mini-i
B205mini-i
RF Performance
  • Power Output >10dBm
  • IIP3 (@ typ NF) -20dBm
  • Typical Noise Figure <8dB
  • Maximum Input Power: 0 dBm
Clocks and Samples Rates
  • Add Clock and Sample Rates
Physical Specifications
Dimensions
Environmental Specifications
  • B200mini 0-40 °C
  • B200mini-i 0-45 °C
  • B205mini-i 0-45 °C
  • B200 0-40 °C
  • B210 0-40 °C
B200mini
B200mini Schematics
B210
B210 Schematics
Datasheets
  • Optional GPSDO (B200/B210 only) - M9107
Mechanical Info
Weight
  • B200mini 24.0 g
  • B200/B210 350 g
Drawings
Enclosures
  • Full Steel Enclosure
USRP B Series Enclosure
FPGA
  • Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.3
B200mini
Slice Logic Utilization
Used Total Percent
Number of Slice Registers 15949 93296 17%
Number of Slice LUTs 19963 46648 42%
Number used as Logic 16140 46648 34%
Number used as Memory 3823 11072 34%
Number used as RAM 972
Number used as SRL 2851
Slice Logic Distribution
Used Total Percent
Number with an unused Flip Flop 7910 23859 33%
Number with an unused LUT 3896 23859 16%
Number of fully used LUT-FF pairs 12053 23859 50%
Number of LUT Flip Flop pairs used 23859
Number of unique control sets 429
IO Utilization
Used Total Percent
Number of bonded IOBs 114 328 34%
IOB Flip Flops/Latches 147
Number of IOs 123
Specific Feature Utilization
Used Total Percent
Number of Block RAM/FIFO 110 172 63%
Number of BUFG/BUFGCTRLs 6 16 37%
Number of DSP48A1s 76 132 57%
Number of PLL_ADVs 1 6 16%
Number using Block RAM only 110
B200
Used Total Percent
Number of Slice Registers 15781 93296 16%
Number of Slice LUTs 19987 46648 42%
Number used as Logic 15983 46648 34%
Number used as Memory 4004 11072 36%
Number used as SRL 3032
Used Total Percent
Number with an unused Flip Flop 8281 24062 34%
Number with an unused LUT 4075 24062 16%
Number of fully used LUT-FF pairs 11706 24062 48%
Number of LUT Flip Flop pairs used 24062
Number of unique control sets 434
IO Utilization
Used Total Percent
Number of bonded IOBs 155 280 55%
IOB Flip Flops/Latches 124
Number of IOs 172
Used Total Percent
Number of Block RAM/FIFO 144 172 83%
Number of BUFG/BUFGCTRLs 3 16 25%
Number using Block RAM only 144
B210
Used Total Percent
Number of Slice Registers 29310 184304 15%
Number of Slice LUTs 36486 92152 39%
Number used as Logic 29279 92152 31%
Number used as Memory 7207 21680 33%
Number used as RAM 1752
Number used as SRL 5455
Used Total Percent
Number with an unused Flip Flop 14325 43635 32%
Number with an unused LUT 7149 43635 16%
Number of fully used LUT-FF pairs 22161 43635 50%
Number of LUT Flip Flop pairs used 43635
Number of unique control sets 723
IO Utilization
Used Total Percent
Number of bonded IOBs 163 338 48%
IOB Flip Flops/Latches 148
Number of IOs 180
Used Total Percent
Number of Block RAM/FIFO 186 268 69%
Number of BUFG/BUFGCTRLs 4 16 25%
Number of DSP48A1s 152 180 84%
Number using Block RAM only 186
Interfaces and Connectivity
B200/B210/B200mini - USB 3.0
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
Application Notes
FAQ
1 RX 1.92 2.112 2.184 2.508
2 RX 2.148 2.436 2.508 2.64
1 TX 2.184 2.34 2.352 2.22
2 TX 2.76 2.88 2.904 2.64
