SBX
The SBX is capable of phase coherent operation, and therefore is suitable for MIMO and Phased Array applications.
- Frequency Range: 400MHz - 4.4GHz
- Versions: 40MHz / 120MHz
- Power Output: 100mW
Environmental Specifications
- 0-40 °C
USRP Compatibility
SBX-40
- N or X Series
SBX-120
- X Series only
SBX
Datasheets
Mechanical Info (size, weight, drawings)
- Add Drawings
RF Connectors
Certificate of Volatility
- SBX
