WBX
Revision as of 16:41, 29 April 2016 by Ettus (Talk | contribs) (Certifications)
The WBX is a wide bandwidth transceiver that provides up to 100 mW of output power and a noise figure of 5 dB. The LO's for the receive and transmit chains operate independently.
The WBX does not provided phase coherent operation, and therefore is not recommended for MIMO and Phased Array applications.
  • Frequency Range: 50MHz - 2.2GHz
  • Versions: 40MHz / 120MHz
  • Power Output: 100mW
  • Noise Figure: 5dB
Physical Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Environmental Specifications
  • 0-40 °C
USRP Compatibility
WBX-40
  • N or X Series
WBX-120
  • X Series only
WBX
WBX Schematics
WBX FE Schematics
Datasheets
HMC472LP4 - digikey link
MGA82563
MGA62563
ADL5387
ADL5385
ADA4937
ADF4350
ADP3336
24LC024
GVA−84+
Mechanical Info (size, weight, drawings)
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Interfaces and Connectivity
Certificate of Volatility
  • WBX
Performance Data
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
