N200/N210
[hide]- 1 Device Overview
- 2 Key Features
- 3 Compatible Daughterboards
- 4 RF Specifications
- 5 Clocks and Samples Rates
- 6 Physical Specifications
- 8 Schematics
- 9 Datasheets
- 10 Mechanical Info
- 11 FPGA
- 13 Multiple Device Configuration
- 14 Certifications
- 15 Certificate of Volatility
- 16 Downloads (FPGA images, E310 images, etc.)
- 17 Application Notes
- 18 FAQ
The USRP Network Series offers high-bandwidth, high-dynamic range processing capability. The Gigabit Ethernet interface of the USRP Network Series allows high-speed streaming capability up to 50 MS/s in both directions (8-bit samples). These features, combined with plug-and-play MIMO capability make the USRP Network an ideal candidate for software defined radio systems with demanding performance requirements.
N200
- Xilinx® Spartan® 3A-DSP 1800 FPGA
- 14 bit 100 MS/s dual ADC
- 16 bit 400 MS/s dual DAC
- Frequency range: DC - 6 GHz with suitable daughterboard
- Up to 50 MS/s in both directions
- Full duplex, SISO (1 Tx & 1 Rx)
- Fully-Coherent MIMO Capability
- Optional GPSDO
- Gigabit Ethernet connectivity
N210
- Xilinx® Spartan® 3A-DSP 3400 FPGA
- Optional GPSDO
- SBX-40
- UBX-40
- WBX-40
- CBX-40
- LFRX / LFTX
- BasicRX / BasicTX
- TVRX2
- DBSRX2
RF Performance (with WBX)
- Phase Noise 1.8 GHz 10kHz -80 dBc/Hz
- Phase Noise 1.8 GHz 100kHz -100 dBc/Hz
- Phase Noise 1.8 GHz 1MHz -137 dBc/Hz
- Power Output 15 dBm
- IIP3 (@ typ NF) 0 dBm
- Typical Noise Figure 5 dB
- FIXME NEEL
Dimensions
22 x 16 x 5 cm
- N200/N210 0-40 °C
N200/N210
Datasheets
- Dual Channel, 16-Bit DAC - AD9777
- Dual Channel, 14-Bit ADC - ADS62P4X
- FPGA - XC3SD3400AFG676 - Double check
- AD56x3
- Clock Distribution IC - AD9510
- Gigabit Ethernet Transceiver - ET1011C2
- Pipelined SRAM - CY7C1354C
- Drivers/Receiver MAX232
Mechanical Info
Weight
1.2 kg
Drawings
FPGA
The available resources on the FPGA will vary depending on the code written for it. Based on the 27 March 2012 FPGA code build, the following resources are available:
USRP N200 (Xilinx Spartan 3A DSP - XC3SD1800A FPGA)
- General Logic:
- Flip Flops: 41% free
- LUTs: 9% free
- Memory: 52% free
- DSP Resources: 64% free
USRP N210 (Xilinx Spartan 3A DSP - XC3SD3400A FPGA)
- General Logic:
- Flip Flops: 59% free
- LUTs: 37% free
- Memory: 68% free
- DSP Resources: 76% free
N200/N210
- Gigabit Ethernet
- [ADD]
- N200/N210
