USRP2
Revision as of 13:09, 30 April 2016 by Ettus (Talk | contribs)
  • (EOL – this product is no longer available for sale through Ettus Research)
  • 50 MHz of RF bandwidth with 8 bit samples
  • 25 MHz of RF bandwidth with 16 bit samples
  • Gigabit Ethernet connectivity
  • MIMO capable - requires two or more USRP2 devices as motherboard has one daughterboard slot (1 RX + 1 TX connectors)
  • Onboard FPGA processing
  • FPGA: Xilinx Spartan XC3S2000
  • ADCs: 14-bits 100 MS/s
  • DACs: 16-bits 400 MS/s
  • Ability to lock to external 5 or 10 MHz clock reference
Basic Hardware Setup
FAQ
What are the available resources on the FPGA?
The available resources on the FPGA will vary depending on the code written for it. Based on the 27 March 2012 FPGA code build, the following resources are available:
USRP2 (Xilinx Spartan 3 - XC3S2000 FPGA)
  • General Logic
  • Memory: 3% free
  • DSP Resources: The FPGA does not have DSP resources
Proper Care and Handling
  • Never apply more than -15 dBm of power into any RF input.
  • Always use at least 30dB attenuation if operating in loopback configuration
Technical support for USRP hardware is available through email only. If the product arrived in a non­functional state or you require technical assistance, please contact s​[email protected]​. Please allow 24 to 48 hours for response by email, depending on holidays and weekends, although we are often able to reply more quickly than that.
Discussions involving the USRP hardware and the UHD software itself are best addressed through the u​srp­-users ​mailing list at http://usrp-users.ettus.com/.
Discussions involving the use of GNU Radio with USRP hardware and UHD software are best addressed through the d​iscuss­gnuradio​mailing list at https://lists.gnu.org/mailman/listinfo/discuss­gnuradio​.
Discussions involving the use of OpenBTS® with USRP hardware and UHD software are best addressed through the o​penbts­discuss​mailing list at https://lists.sourceforge.net/lists/listinfo/openbts­discuss​.​
The support page on our website is located at h​ttp://www.ettus.com/support​. The Knowledge Base is located at ​http://www.ettus.com/kb​.
Legal Considerations
Sales and Ordering Support
If you have any non­technical questions related to your order, then please contact us by email at [email protected]​, or by phone at +1­408­610­6399 (Monday­Friday, 8 AM 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
Terms and Conditions of Sale
