Implementation of a Simple FM Receiver in GNU Radio
Revision as of 12:48, 1 May 2016 by Ettus (Talk | contribs) (→‎Application Note Number)
AN-5501
2016-05-01 Neel Pandeya Initial creation
This AN shows a quick and simple implementation of an FM receiver for the USRP using GNU Radio. The goal is to easily demonstrate a practical application, and to verify that the USRP is functioning properly.
In this application note, a Universal Software Radio Peripheral (USRP™) N200/N210 and a WBX daughterboard is used with GNU Radio to build a simple FM receiver. The intent of this example is to:
  • Teach some basic DSP and RF concepts including: filtering, demodulation, and sample rate conversion.
  • Show how to build graphical applications with GNU Radio Companion
  • Illustrate the simplicity of the software tools that can be used with the USRP product family.
Requirements
  • USRP with compatible daughterboard to receive 88-108 MHz
  • GNU Radio
  • UHD
Blocks
UHD Source Block
  • Configures USRP
  • Receives data stream from USRP
FFT Sink
  • Display Fast Fourier Transform of data stream
Low Pass Filter
  • Apply low pass filter to data stream
  • Optional: Decimation or Interpolation
WBFM Receive
  • Demodulates Wide Band Frequency Modulated signal from data stream
Rational Resampler
  • Decimate or Interpolate data stream to desired sample rate
Audio Sink
  • Audio hardware interface
  • Optional: Decimate Audio Rate
Wav File Sink
  • Save data stream as WAV file type
WX Widgets
  • Textbox - Input field
  • Slider - Adjustable slider
  • Notebook - Assign Widgets/GUI Sinks to tabs within flowgraph
Variable
  • Creates variable within flowgraph
Video
https://www.youtube.com/watch?v=KWeY2yqwVA0
You can download the sample GRC file here: http://files.ettus.com/app_notes/fm_rcvr/fm_example.grc
