LFTX/LFRX
[hide]- 1 Device Overview
- 2 Key Features
- 3 RF Specifications
- 4 Physical Specifications
- 5 Environmental Specifications
- 6 USRP Compatibility
- 7 Schematics
- 8 Datasheets
- 9 Mechanical Info (size, weight, drawings)
- 10 Interfaces and Connectivity
- 11 Certifications
- 12 Certificate of Volatility
- 13 Performance Data (DB only)
- 14 Downloads
The LFTX daughterboard utilizes two high-speed operational amplifiers to allow transmission from 0-30 MHz. The LFTX is ideal for applications in the HF band, or for applications using an external front end to up-convert and amplify the intermediate signal. The outputs of the LFTX can be processed independently, or as a single I/Q pair. Example applications include HF communications, radios with external front ends and direct signal generation below 30 MHz.
- DC-30Mhz coverage
- 0-40 °C
USRP Compatibility
LFRX
- N or X Series
LFTX
- N or X Series
LFRX
LFTX
Datasheets
AD813x - verify
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
- LFTX/LFRX
