UBX
Revision as of 15:48, 1 May 2016 by Ettus (Talk | contribs) (Interfaces and Connectivity)
The UBX daughterboard is a full-duplex wideband transceiver that covers frequencies from 10 MHz to 6 GHz. Coherent and phase-aligned operation across multiple UBX daughterboards on USRP X Series motherboards enables users to explore MIMO and direction finding applications. The UBX daughterboard works interchangeably with other USRP daughterboards and is supported by the USRP Hardware Driver™ (UHD) software API for seamless integration into existing applications.
The UBX is capable of phase coherent operation, and therefore is suitable for MIMO and Phased Array applications, on the X Series. Additionally this capability is only available on the X Series devices.
  • RF shielding
  • Full duplex operation with independent TX and RX frequencies
  • Synthesizer synchronization for applications requiring coherent or phase-aligned operation, supported on USRP X Series motherboards only
  • Frequency Range: 10 MHz - 6 GHz
  • Versions: 40MHz / 160MHz
  • Noise Figure
    • 10 - 20 MHz: 3 - 4 dB
    • 20 - 500 MHz: 2 - 3 dB
    • 0.5 - 1.5 GHz: 2 - 4 dB
    • 1.5 - 4 GHz: 4 - 5 dB
    • 4 - 6 GHz: 5-7 dB
  • RX IIP3 (Max)*
    • 10** - 35 MHz: 4 - 10 dBm
    • 35 - 500 MHz: 10 - 12 dBm
    • 0.5 - 1.5 GHz: 8 - 13 dBm
    • 1.5 - 6 GHz: 8 - 9 dBm
  • RX IQ Imbalance
    • 10 MHz - 6 GHz: < -30dBc
  • TX Power (Max)
    • 10 MHz - 3.5 GHz: > 20 dBm
    • 3.5 - 4 GHz: 18 - 20 dBm
    • 4 - 5 GHz: 13 - 18 dBm
    • 5 - 6 GHz: 7 - 13 dBm
  • TX OIP3
    • 10 - 500 MHz: > 40 dBm
    • 0.5 - 3 GHz: > 36 dBm
    • 3 - 5 GHz: > 30 dBm
    • 5 - 6 GHz: > 26 dBm
  • TX IQ Imbalance
    • 10 MHz - 6 GHz: < -30 dBc
Note: * Noise Figure < 10 dB
Note: ** High Gain at 10 MHz
Physical Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Environmental Specifications
  • 0-40 °C
USRP Compatibility
UBX-40
  • N or X Series
UBX-160
  • X Series only
UBX
UBX Schematics
Datasheets
MAX2871
ADL5375-05
LFCN-2250+
LTC5510
LFCN-490+
HMC624LP4E
NBB-400
PHA-1+
ADA4927-2
ADL5380
MGA-62563
LFCN-1700+
VMMK-3603
LFCN-2600+
855916
LTC5510
LFCN-2600+
TCM1-63AX+
ADA4927-2
AD8591
ADL5380
ZXTC2062E6
NFA21SL
HMC624ALP4E
LFCN-800+
ADP7104-3.3
ADL5375-05
LTC5510
24LC024
ADP7104-5.0
ZXTC2062E6
Mechanical Info
  • Add Drawings
RF Connectors
  • The UBX daughterboard features female SMA connectors for both the TX/RX and RX2 connectors.
Certificate of Volatility
  • UBX
Important Notes
  • A larger 24W (6V, 4A) power supply is required when using a UBX-40 daughterboard and integrated GPS Disciplined Oscillator accessory together in a USRP2, USRP N200, or USRP N210 device.
  • The UBX-160 transmitter path has 160 MHz of bandwidth throughout the full frequency range of the device; the receiver path has 84 MHz of bandwidth for center frequencies from 10 MHz to 500 MHz.
Performance Data
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
