WBX
[hide]Device Overview
The WBX is a wide bandwidth transceiver that provides up to 100 mW of output power and a noise figure of 5 dB. The LO's for the receive and transmit chains operate independently.
The WBX does not provided phase coherent operation, and therefore is not recommended for MIMO and Phased Array applications.
- Frequency Range: 50MHz - 2.2GHz
- Versions: 40MHz / 120MHz
- Power Output: 100mW
- Noise Figure: 5dB
Physical Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Environmental Specifications
- 0-40 °C
USRP Compatibility
WBX-40
- N or X Series
WBX-120
- X Series only
WBX
Datasheets
ADA4937 -- Ultralow Distortion Differential ADC Driver
ADP3336 -- High Accuracy Ultralow IQ, 500 mA anyCAP® Adjustable Low Dropout Regulator
ADL5387 -- 50 MHz to 2 GHz Quadrature Demodulator
ADL5385 -- 50 MHz to 2200 MHz Quadrature Modulator
ADF4350 / ADF4351 -- Wideband Synthesizer with Integrated VCO Verification needed
HMC472LP4 - digikey link
Mechanical Info
- Add Drawings
RF Connectors
- The WBX daughterboard features female MCX connectors for both the TX/RX and RX2 connectors.
Certificate of Volatility
- WBX
