CBX
Revision as of 16:04, 1 May 2016 by Ettus (Talk | contribs) (RF Specifications)
The CBX is a full-duplex, wideband transceiver that covers a frequency band from 1.2 GHz to 6 GHz with a instantaneous bandwidth of 40 MHz or 120 MHz. The CBX can serve a wide variety of application areas, including WiFi research, cellular base stations, cognitive radio research, and RADAR.
The CBX does not provided phase coherent operation, and therefore is not recommended for MIMO and Phased Array applications.
Physical Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Environmental Specifications
  • 0-40 °C
USRP Compatibility
CBX-40
  • N or X Series
CBX-120
  • X Series only
CBX
CBX Schematics
Datasheets
VMMK-3603
AS225-313LF
HMC624LP4E
MGA82563
GVA-84+
PHA-1+
ADL5380ACPZ
ADA4927-2YCPZ
AD8591ARTZ-REEL
NC7WZ04P6X
MAX2870ETJ+
SKY13267-321
LFCN-2000+
LP3878MR-ADJ
24LC024
ADL5375-05
Mechanical Info
  • Add Drawings
RF Connectors
  • The CBX daughterboard features female SMA connectors for both the TX/RX and RX2 connectors.
Certificate of Volatility
  • CBX
Performance Data
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
