N200/N210
Revision as of 20:40, 2 May 2016 by Ettus (Talk | contribs) (Certificate of Volatility)
The USRP Network Series offers high-bandwidth, high-dynamic range processing capability. The Gigabit Ethernet interface of the USRP Network Series allows high-speed streaming capability up to 50 MS/s in both directions (8-bit samples). These features, combined with plug-and-play MIMO capability make the USRP Network an ideal candidate for software defined radio systems with demanding performance requirements.
N200
  • 50 MHz of RF bandwidth with 8 bit samples
  • 25 MHz of RF bandwidth with 16 bit samples
  • Gigabit Ethernet connectivity
  • MIMO capable - requires two or more USRP N200 devices as motherboard has one daughterboard slot (1 RX + 1 TX connectors)
  • Onboard FPGA processing
  • FPGA: Xilinx® Spartan® 3A-DSP XC3SD1800A
  • ADCs: 14-bits 100 MS/s
  • DACs: 16-bits 400 MS/s
  • Ability to lock to external 5 or 10 MHz clock reference
  • TCXO Frequency Reference (~2.5ppm)
  • Optional internal GPS locked reference oscillator
  • FPGA code can be changed with Xilinx® ISE® WebPACK™ tools
  • Frequency range: DC - 6 GHz with suitable daughterboard
N210
  • MIMO capable - requires two or more USRP N210 devices as motherboard has one daughterboard slot (1 RX + 1 TX connectors)
  • FPGA: Xilinx® Spartan® 3A-DSP XC3SD3400A
  • FPGA code can only be changed with the paid version of the Xilinx® ISE® Design Suite tools
Compatible Daughterboards
  • SBX-40
  • UBX-40
  • WBX-40
  • CBX-40
  • LFRX / LFTX
  • BasicRX / BasicTX
  • TVRX2
  • DBSRX2
RF Performance (with WBX)
  • Phase Noise 1.8 GHz 10kHz -80 dBc/Hz
  • Phase Noise 1.8 GHz 100kHz -100 dBc/Hz
  • Phase Noise 1.8 GHz 1MHz -137 dBc/Hz
  • Power Output 15 dBm
  • IIP3 (@ typ NF) 0 dBm
  • Typical Noise Figure 5 dB
Clocks and Samples Rates
  • FIXME NEEL
Physical Specifications
Dimensions
22 x 16 x 5 cm
Environmental Specifications
  • N200/N210 0-40 °C
N200/N210
N200/N210 Schematics
Datasheets
  • Dual Channel, 16-Bit DAC - AD9777
  • AD56x3
  • Clock Distribution IC - AD9510
  • Gigabit Ethernet Transceiver - ET1011C2
Mechanical Info
Weight
1.2 kg
Drawings
FPGA
  • Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.4
N200
Device utilization summary:
Selected Device : 3sd1800afg676-5
 Number of Slices:                    18356  out of  16640   110% (*)
 Number of Slice Flip Flops:          20466  out of  33280    61%
 Number of 4 input LUTs:              32968  out of  33280    99%
    Number used as logic:             28511
    Number used as Shift registers:    3945
    Number used as RAMs:                512
 Number of IOs:                         338
 Number of bonded IOBs:                 331  out of    519    63%
    IOB Flip Flops:                     342
 Number of BRAMs:                        41  out of     84    48%
 Number of GCLKs:                         6  out of     24    25%
 Number of DCMs:                          1  out of      8    12%
 Number of DSP48s:                       31  out of     84    36%
N210
Selected Device : 3sd3400afg676-5
 Number of Slices:                    18349  out of  23872    76%
 Number of Slice Flip Flops:          20475  out of  47744    42%
 Number of 4 input LUTs:              32986  out of  47744    69%
    Number used as logic:             28529
 Number of IOs:                         338
 Number of bonded IOBs:                 331  out of    469    70%
    IOB Flip Flops:                     342
 Number of BRAMs:                        41  out of    126    32%
 Number of DSP48s:                       31  out of    126    24%
Interfaces and Connectivity
N200/N210
  • Gigabit Ethernet
Multiple Device Configuration
  • [ADD]
N200/N210
Downloads (FPGA images, E310 images, etc.)
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
Application Notes
FAQ
