SBX
[hide]Device Overview
The SBX is capable of phase coherent operation, and therefore is suitable for MIMO and Phased Array applications.
Environmental Specifications
- 0-40 °C
USRP Compatibility
SBX-40
- N or X Series
SBX-120
- X Series only
SBX
Datasheets
Mechanical Info
- Add Drawings
RF Connectors
