B200/B210/B200mini/B205mini Getting Started Guides
[hide]- 1 Kit Contents
- 3 You Will Need
- 4 Proper Care and Handling
- 6 Connect the USRP to the Host Computer
- 7 Test and Verify the Operation of the USRP
- 8 Technical Support and Community Knowledge Base
- 9 Legal Considerations
- 10 Sales and Ordering Support
- 11 Terms and Conditions of Sale
Kit Contents
- USRP B200 / B210 / B200mini / B205mini
- USB 3.0 Cable
- Universal power supply (B210 only)
You Will Need
- A host computer with an available USB 2.0 or 3.0 port
Never apply more than 0 dBm of power into any RF input. | |
Always use at least 30dB attenuation if operating in loopback configuration |
In order to use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes. Release 3.8.4 or later of the USRP Hardware Driver, UHD, is required. It is recommended to use the latest stable version of UHD that is available.
If you have a USB stick with the LiveUSB SDR Environment installed on it, then you may boot your host computer from that. The LiveUSB SDR Environment does not require anything to be installed on your host computer, and contains a Linux-based environment with the UHD software and the GNU Radio framework already installed. More information about the Live SDR Environment is available at the Live SDR Environment Getting Started Guides page.
The included USB 3.0 cable provides power and data connectivity for the USRP Bus Series. The host-side of the cable must be plugged into either a USB 2.0 or 3.0 port. Note that the USB 2.0 link provides less bandwidth than the USB 3.0 link. Also note that an external DC power supply must be connected if using a GPSDO (B200/B210 only). More information about USB bandwidth constraints and power considerations is available on the USRP B200 and B210 - USB 3.0 Streaming Rate Benchmarks Application Note.
Once the software tools are installed on the host computer, or using the Live SDR Environment, verify the correct operation of the USRP by running the utility programs on the host computer. More information is available at the Verifying the Operation of the USRP Using UHD and GNU Radio Application Note.
Technical support for USRP hardware is available through email only. If the product arrived in a nonfunctional state or you require technical assistance, please contact support@ettus.com. Please allow 24 to 48 hours for response by email, depending on holidays and weekends, although we are often able to reply more quickly than that.
Discussions involving the USRP hardware and the UHD software itself are best addressed through the usrp-users mailing list at http://usrp-users.ettus.com/.
Discussions involving the use of GNU Radio with USRP hardware and UHD software are best addressed through the discussgnuradiomailing list at https://lists.gnu.org/mailman/listinfo/discussgnuradio.
Discussions involving the use of OpenBTS® with USRP hardware and UHD software are best addressed through the openbtsdiscussmailing list at https://lists.sourceforge.net/lists/listinfo/openbtsdiscuss.
The support page on our website is located at http://www.ettus.com/support. The Knowledge Base is located at http://www.ettus.com/kb.
If you have any nontechnical questions related to your order, then please contact us by email at orders@ettus.com, or by phone at +14086106399 (Monday-Friday, 8 AM - 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
