B200/B210/B200mini/B205mini/B206mini Getting Started Guides
Revision as of 22:48, 2 May 2016 by Ettus (Talk | contribs) (Connect the USRP to the Host Computer)
Kit Contents
  • USRP B200 / B210 / B200mini / B205mini
  • USB 3.0 Cable
  • Universal power supply (B210 only)
You Will Need
  • A host computer with an available USB 2.0 or 3.0 port
Proper Care and Handling
Never apply more than 0 dBm of power into any RF input.
In order to use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes. Release 3.8.4 or later of the USRP Hardware Driver, UHD, is required. It is recommended to use the latest stable version of UHD that is available.
The included USB 3.0 cable provides power and data connectivity for the USRP Bus Series. The host-side of the cable must be plugged into either a USB 2.0 or 3.0 port. Note that the USB 2.0 link provides less bandwidth than the USB 3.0 link. Also note that an external DC power supply must be connected if using a GPSDO (B200/B210 only).
Test and Verify the Operation of the USRP
Once the software tools are installed on the host computer, or using the Live SDR Environment, verify the correct operation of the USRP by running the utility programs on the host computer. More information is available at the Verifying the Operation of the USRP Using UHD and GNU Radio Application Note.
Technical support for USRP hardware is available through email only. If the product arrived in a non­functional state or you require technical assistance, please contact s​[email protected]​. Please allow 24 to 48 hours for response by email, depending on holidays and weekends, although we are often able to reply more quickly than that.
Discussions involving the USRP hardware and the UHD software itself are best addressed through the u​srp­-users ​mailing list at http://usrp-users.ettus.com/.
Discussions involving the use of GNU Radio with USRP hardware and UHD software are best addressed through the d​iscuss­gnuradio​mailing list at https://lists.gnu.org/mailman/listinfo/discuss­gnuradio​.
Discussions involving the use of OpenBTS® with USRP hardware and UHD software are best addressed through the o​penbts­discuss​mailing list at https://lists.sourceforge.net/lists/listinfo/openbts­discuss​.​
The support page on our website is located at h​ttp://www.ettus.com/support​. The Knowledge Base is located at ​http://www.ettus.com/kb​.
Legal Considerations
Sales and Ordering Support
If you have any non­technical questions related to your order, then please contact us by email at [email protected]​, or by phone at +1­408­610­6399 (Monday-Friday, 8 AM - 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
Terms and Conditions of Sale
