N200/N210
[hide]- 1 Device Overview
- 2 Key Features
- 3 Compatible Daughterboards
- 4 RF Specifications
- 5 Clocks and Samples Rates
- 6 Physical Specifications
- 8 Schematics
- 9 Datasheets
- 10 Mechanical Info
- 11 FPGA
- 13 Multiple Device Configuration
- 14 Certifications
- 15 Certificate of Volatility
- 16 Downloads (FPGA images, E310 images, etc.)
- 17 Application Notes
The USRP Network Series offers high-bandwidth, high-dynamic range processing capability. The Gigabit Ethernet interface of the USRP Network Series allows high-speed streaming capability up to 50 MS/s in both directions (8-bit samples). These features, combined with plug-and-play MIMO capability make the USRP Network an ideal candidate for software defined radio systems with demanding performance requirements.
N200
N210
- SBX-40
- UBX-40
- WBX-40
- CBX-40
- LFRX / LFTX
- BasicRX / BasicTX
- TVRX2
- DBSRX2
RF Performance (with WBX)
- Phase Noise 1.8 GHz 10kHz -80 dBc/Hz
- Phase Noise 1.8 GHz 100kHz -100 dBc/Hz
- Phase Noise 1.8 GHz 1MHz -137 dBc/Hz
- Power Output 15 dBm
- IIP3 (@ typ NF) 0 dBm
- Typical Noise Figure 5 dB
- FIXME NEEL
Dimensions
22 x 16 x 5 cm
- N200/N210 0-40 °C
N200/N210
Datasheets
Part Number | Description | Schematic ID | Schematic Page |
AD9777 | Dual Channel, 16-Bit DAC | ||
ADS62P4X | Dual Channel, 14-Bit ADC | ||
XC3SD3400AFG676 | FPGA | ||
AD56x3 | |||
AD9510 | Clock Distribution IC | ||
ET1011C2 | Gigabit Ethernet Transceiver | ||
CY7C1354C | Pipelined SRAM | ||
MAX232 | Drivers/Receiver |
Mechanical Info
Weight
1.2 kg
Drawings
FPGA
- Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.4
N200
Device utilization summary: --------------------------- Selected Device : 3sd1800afg676-5 Number of Slices: 18356 out of 16640 110% (*) Number of Slice Flip Flops: 20466 out of 33280 61% Number of 4 input LUTs: 32968 out of 33280 99% Number used as logic: 28511 Number used as Shift registers: 3945 Number used as RAMs: 512 Number of IOs: 338 Number of bonded IOBs: 331 out of 519 63% IOB Flip Flops: 342 Number of BRAMs: 41 out of 84 48% Number of GCLKs: 6 out of 24 25% Number of DCMs: 1 out of 8 12% Number of DSP48s: 31 out of 84 36%
N210
Device utilization summary: --------------------------- Selected Device : 3sd3400afg676-5 Number of Slices: 18349 out of 23872 76% Number of Slice Flip Flops: 20475 out of 47744 42% Number of 4 input LUTs: 32986 out of 47744 69% Number used as logic: 28529 Number used as Shift registers: 3945 Number used as RAMs: 512 Number of IOs: 338 Number of bonded IOBs: 331 out of 469 70% IOB Flip Flops: 342 Number of BRAMs: 41 out of 126 32% Number of GCLKs: 6 out of 24 25% Number of DCMs: 1 out of 8 12% Number of DSP48s: 31 out of 126 24%
N200/N210
- Gigabit Ethernet
- [ADD]
N200/N210
