Revision as of 18:03, 10 May 2016 by Ettus (Talk | contribs) (Hardware Specifications)
B200
B210
B200mini
B200mini-i
B205mini-i
RF Performance
  • Power Output >10dBm
  • IIP3 (@ typ NF) -20dBm
  • Typical Noise Figure <8dB
  • Maximum Input Power: 0 dBm
B200
  • Current Hardware Revision: 5
  • Minimum version of UHD required: 3.9.0
  • B200 Rev 5 (AD9364-based board) requires minimum UHD 3.8.4
B210
B200mini
  • Current Hardware Revision: x
B200mini-i
B205mini-i
  • Minimum version of UHD required: 3.9.2
Clocks and Samples Rates
  • FIXME NEEL
Physical Specifications
Dimensions
Environmental Specifications
  • B200mini 0-40 °C
  • B200mini-i 0-45 °C
  • B205mini-i 0-45 °C
  • B200 0-40 °C
  • B210 0-40 °C
B200mini
B200mini Schematics
B210
B210 Schematics
Key Component Datasheets
Part Number Description Schematic ID Schematic Page
Analog Devices AD9364 RF Transceiver
Analog Devices AD9361 RF Transceiver
Xilinx Spartan-6 Product Page FPGA
XC6SLX75 / XC6SLX150 FPGA
ADF4001 Frequency Synthesizer
CYUSB3014 FX3: SuperSpeed USB Controller
SKY13317 Antenna Switch
BD3150L50100A00 Balun
PGA−102+ Amplifier
B200mini VXTCXO VXTCXO (B200mini only)
M9107 Optional GPSDO (B200/B210 only)
Mechanical Info
Weight
  • B200mini 24.0 g
  • B200/B210 350 g
Drawings
Enclosures
USRP B200/B210 Enclosure
  • Full Steel Enclosure
FPGA
  • Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.4
B200
Device utilization summary:
Slice Logic Utilization:
Slice Logic Distribution:
IO Utilization:
Specific Feature Utilization:
B210
IO Utilization:
B200mini
IO Utilization:
B205mini
IO Utilization:
Interfaces and Connectivity
B200/B210/B200mini - USB 3.0
Multiple Device Configuration
  • [ADD]
Certificate of Volatility
B200/B210
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
FAQ
1 RX 1.92 2.112 2.184 2.508
2 RX 2.148 2.436 2.508 2.64
1 TX 2.184 2.34 2.352 2.22
2 TX 2.76 2.88 2.904 2.64
