USRP N Series Quick Start (Daughterboard Installation)
Revision as of 20:39, 11 May 2016 by Ettus (Talk | contribs) (UHD FFT)
Introduction
Organization: Ettus Research
This Quick Start is meant to show you how to put together your new N200/N210. We will start with installing a WBX daughterboard and go all the way to being able to ping the device, performing a quick software probe to verify hardware components and finally running a simple FFT demo. This Quick Start does not cover the installation of software on the host computer. If you have not installed UHD/Gnuradio on your system, please reference the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes. You may also use the Live SDR Environment to perform the verification steps for your USRP. Detailed information on the Live SDR Environment is available at the Live SDR Environment Getting Started Guides page.
Tools Required
  • Philips Screwdriver
  • Torx Screwdriver
  • 5/16” wrench
  • ESD Mat
  • ESD Wrist strap
  • ESD Gloves
Pre-installed Software
Parts Checklist
  • 1 x USRP N200/N210
  • 1 x Power Supply and US Cord
  • 1 x Gigabit Ethernet Cable
  • 2 x SMA-Bulkhead Cables (SMA to MCX)
  • 1 x WBX Daughterboards
  • 6 x Daughterboard Screws
  • One or more Antennas
Proper Handling
All Ettus Research products are individually tested before shipment. The USRP™ is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the USRP™ can easily cause the device to become non-functional. Ettus Research recommends you perform the installation with no power to the USRP and using ESD equipment. Listed below are some examples of actions which can prevent damage to the unit:
  • Never apply more than -15 dBm of power into any RF input.
  • Always use at least 30dB attenuation if operating in loopback configuration
Installation Process
Step 1
Unscrew the 2 screws on the back of the USRP and remove the top cover. (Lift up about 15 degrees and wiggle back as there is a flange on the front part of the cover)
Step 2
Line up the 6 of the 8 screw holes on the Daughterboard with the USRP Motherboard standoffs (they only go one way). The WBX will only use 6 of the mounting points.
Step 3
Step 4
Put 6 of the screws provided in the daughterboard
Step 5
It is recommended to connect the bulkhead cables one at a time to avoid confusion. Note which front panel point (RF1, RF2) you install each connector from the daughterboard to (TX/RX, RX2).
Step 6
Step 8
Connect the Gigabit Ethernet cable and power cord provided (do not plug in the power adapter to the wall outlet)
Step 7
Step 9
  • Note: The N200/N210 only supports 1 GigE ethernet speeds
Step 10
Power on the USRP (by plugging in the power adapter into wall outlet)
Step 11
   $ ping 192.168.10.2
Example Output:
   $ ping 192.168.10.2
   64 bytes from 192.168.10.2: icmp_seq=1 ttl=32 time=0.994 ms
   64 bytes from 192.168.10.2: icmp_seq=2 ttl=32 time=1.35 ms
   64 bytes from 192.168.10.2: icmp_seq=3 ttl=32 time=1.06 ms
   64 bytes from 192.168.10.2: icmp_seq=4 ttl=32 time=1.33 ms
   ^C
   4 packets transmitted, 4 received, 0% packet loss, time 3004ms
   rtt min/avg/max/mdev = 0.994/1.187/1.354/0.166 ms
Step 12
Assuming you have properly installed the UHD driver (http://code.ettus.com/redmine/ettus/projects/uhd/wiki) you can now run this command in a terminal/command window:
   $ uhd_usrp_probe
This will tell you about the hardware inside of your USRP. Example output below.
   $ uhd_usrp_probe
   linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.010.git-156-g2d68f228
   -- Opening a USRP2/N-Series device...
   -- Current recv frame size: 1472 bytes
   -- Current send frame size: 1472 bytes
   -- Detecting internal GPSDO.... No GPSDO found
   |       Device: USRP2 / N-Series Device
   |   |       Mboard: N210r4
   |   |   hardware: 2577
   |   |   mac-addr: 00:00:00:00:00:00
   |   |   ip-addr: 192.168.10.2
   |   |   subnet: 255.255.255.255
   |   |   gateway: 255.255.255.255
   |   |   gpsdo: none
   |   |   serial: xxxxxxx
   |   |   FW Version: 12.4
   |   |   FPGA Version: 11.1
   |   |   Time sources: none, external, _external_, mimo
   |   |   Clock sources: internal, external, mimo
   |   |   Sensors: mimo_locked, ref_locked
   |   |   |       RX DSP: 0
   |   |   |   Freq range: -50.000 to 50.000 MHz
   |   |   |       RX DSP: 1
   |   |   |       RX Dboard: A
   |   |   |   ID: WBX, WBX + Simple GDB (0x0053)
   |   |   |   Serial: xxxxxxxx
   |   |   |   |   Antennas: TX/RX, RX2, CAL
   |   |   |   |   Sensors: lo_locked
   |   |   |   |   Freq range: 68.750 to 2200.000 MHz
   |   |   |   |   Gain range PGA0: 0.0 to 31.5 step 0.5 dB
   |   |   |   |   Bandwidth range: 40000000.0 to 40000000.0 step 0.0 Hz
   |   |   |   |   Gain range digital: 0.0 to 6.0 step 0.5 dB
   |   |   |   |   Gain range fine: 0.0 to 0.5 step 0.1 dB
   |   |   |       TX DSP: 0
   |   |   |       TX Dboard: A
   |   |   |   Serial: xxxxxxxx
   |   |   |   |   Antennas: TX/RX, CAL
   |   |   |   |   Sensors: lo_locked
   |   |   |   |   Gain range PGA0: 0.0 to 25.0 step 0.1 dB
UHD FFT
1. Connect an antenna to TX/RX
2.From the terminal run the command below. This command will start uhd_fft and tune the USRP to 100 MHz using the TX/RX antenna with 10 dB gain and a sample rate of 10 MS/s.
   $ uhd_fft --args "addr=192.168.10.2" -A TX/RX -s 10e6 -g 10 -f 100e6
Success
Congratulations! You have successfully setup and verified your new USRP N200/N210. A more detailed verification guide is at the Verifying the Operation of the USRP Using UHD and GNU Radio application note. For additional step-by-step guides to using your USRP N200/N210, see the Application Notes section of the Ettus Research Knowledge Base.
