BasicTX/BasicRX
Revision as of 22:18, 11 May 2016 by Ettus (Talk | contribs) (RF Specifications)
The BasicRx/BasicTx daughterboards are low-cost daughterboards that provides direct access to the ADC inputs. The boards can accept real-mode signals from 1 to 250 MHz. The BasicRx/BasicTx is ideal for applications using an external front end providing relatively clean signals within operable bandwidth. Wideband transformers couple each RF input to a single channel of the USRP device's ADC. The signals sampled by the ADC are manipulated in the FPGA, and can be processed as two real-mode signals, or a single I-Q pair.
  • 1-250 MHz coverage
  • Real or Complex sampling
Hardware Specifications
BasicRX
  • Details
BasicTX
  • Details
Environmental Specifications
  • 0-40 °C
USRP Compatibility
BasicRX
  • N or X Series
BasicTX
  • N or X Series
Basic RX
Basic RX Schematics
Basic TX
Basic TX Schematics
Key Component Datasheets
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum?
Mechanical Info
  • Add Drawings
RF Connectors
  • The BasicTX/RX daughterboard features female SMA connectors for both the RX and TX connectors.
Certificate of Volatility
  • BasicTX/BasicRX
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
