SBX
[hide]Device Overview
The SBX is capable of phase coherent operation, and therefore is suitable for MIMO and Phased Array applications.
Hardware Specifications
SBX
- Details
Environmental Specifications
- 0-40 °C
USRP Compatibility
SBX-40
- N or X Series
SBX-120
- X Series only
SBX
Key Component Datasheets
Part Number | Description | Schematic ID | Schematic Page |
MGA82563 | |||
AS225-313LF | |||
HMC624LP4E | |||
LFCN-5850+ | |||
PHA-1+ | |||
GVA-84+ | |||
ADL5380ACPZ | |||
ADA4927-2YCPZ | |||
AD8591ARTZ-REEL | |||
NC7WZ04P6X | |||
ADF4350BCPZ | |||
SKY13267-321 | |||
LFCN-1200+ | |||
TC1-1-43A+ | |||
LP3878MR-ADJ | |||
NC7WZ04P6X | |||
24LC024 | |||
ADL5375 | |||
SKY13267 |
Mechanical Info
- Add Drawings
RF Connectors
