WBX
Revision as of 23:41, 11 May 2016 by Ettus (Talk | contribs) (Key Component Datasheets)
The WBX is a wide bandwidth transceiver that provides up to 100 mW of output power and a noise figure of 5 dB. The LO's for the receive and transmit chains operate independently.
The WBX does not provided phase coherent operation, and therefore is not recommended for MIMO and Phased Array applications.
  • Frequency Range: 50MHz - 2.2GHz
  • Versions: 40MHz / 120MHz
  • Power Output: 100mW
  • Noise Figure: 5dB
Hardware Specifications
WBX-40
  • Details
WBX-120
  • Details
Environmental Specifications
  • 0-40 °C
USRP Compatibility
WBX-40
  • N or X Series
WBX-120
  • X Series only
WBX
WBX Schematics
WBX FE Schematics
Part Number Description Schematic ID Schematic Page
ADA4937 Ultralow Distortion Differential ADC Driver
ADP3336 High Accuracy Ultralow IQ, 500 mA anyCAP® Adjustable Low Dropout Regulator
ADL5387 50 MHz to 2 GHz Quadrature Demodulator
ADL5385 50 MHz to 2200 MHz Quadrature Modulator
ADF4350 / ADF4351 Wideband Synthesizer with Integrated VCO Verification needed
HMC472LP4 digikey link
MGA82563
MGA62563
24LC024
GVA−84+
Mechanical Info
  • Add Drawings
RF Connectors
  • The WBX daughterboard features female MCX connectors for both the TX/RX and RX2 connectors.
Certificate of Volatility
WBX-40/WBX-120
Performance Data
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
