GPSDO
Revision as of 12:05, 12 May 2016 by Ettus (Talk | contribs) (→‎Specifications)
GPSDO Kit
Product Compatibility
  • N200/N210
  • E100/E110
Specifications
Module Specifications
1 PPS Accuracy ±50ns to UTC RMS (1-Sigma) GPS Locked
Holdover Stability <±11μs over 3 hour period at +25C
1 PPS Output (OCXO Flywheel Generated) 3.3VDC CMOS
RS-232 Control NMEA & SCPI-99 Control Commands, Integrated into UHD
GPS Frequency L1, C/A 1574MHz
GPS Antenna Active (3V compatible) or Passive
GPS Receiver 50 Channels, Mobile, WAAS, EGNOS, MSAS capable
Sensitivity Acquisition -144dBm, Tracking -160dBm
TTFF Cold Start: <45 sec, Warm Start: 1 sec, Hot Start: 1 sec
ADEV 1E-11 at 1s
Warm Up Time / Stabilization Time <5 min at +25C to 1E-08 Accuracy
Supply Voltage (Vdd) 6VDC
Power Consumption <1.8W Max, 1.35W Typical
Operating Temperature 0C to +60C
Storage Temperature -45C to 85C
Oscillator Specifications
Frequency Output 10MHz
10MHz Retrace ±2E-08 after 1 hour at 25C
Frequency Stability Over Temperature (Unlock Condition) ±2.5E-08
Warm Up Time < 1 min at +25C
Phase Noise at 10MHz 1Hz -80dBc/Hz
10Hz -110dBc/Hz
100Hz -135dBc/Hz
1kHz -145dBc/Hz
10kHz <-145dBc/Hz
Installation Guide
Media:gpsdo-kit 4.pdf
Certificate of Volatility
  • GPSDO Kit
GPSDO (OCXO)
  • X300/X310
Specifications
Specifications
Holdover Stability <±20μs over 3 hour period at +25C
GPS Antenna Active (5V compatible) or Passive
Sensitivity Acquisition -142dBm, Tracking -168dBm
ADEV 1E-11 at 1s
Supply Voltage (Vdd) 3.3/5VDC
Power Consumption 0.7W Max
Phase Noise at 10MHz 1Hz -75dBc/Hz
10Hz -110dBc/Hz
100Hz -132dBc/Hz
1kHz -142dBc/Hz
10kHz <-145dBc/Hz
GPSDO (TCXO)
  • B200/B210
Specifications
ADEV 1E-11 at 1s
Supply Voltage (Vdd) 3.3V
Power Consumption 0.5W Max
Frequency Stability Over Temperature (Unlock Condition) ±7.5E-08
Phase Noise at 10MHz 1Hz -65dBc/Hz
10Hz -102dBc/Hz
100Hz -132dBc/Hz
10kHz <-152dBc/Hz
