USRP1
Revision as of 13:30, 13 May 2016 by Ettus (Talk | contribs) (Technical Support and Community Knowledge Base)
  • (EOL – this product is no longer available for sale through Ettus Research)
  • 16 MHz of RF bandwidth with 8 bit samples
  • 8 MHz of RF bandwidth with 16 bit samples (RX Only)
  • USB 2.0 high speed connectivity
  • MIMO with a single USRP device the motherboard has two daughterboard slots (2 RX + 2 TX connectors)
  • FPGA: Altera Cyclone
  • ADCs: 12-bits 64 MS/s
  • DACs: 14-bits 128 MS/s
Basic Hardware Setup
Proper Care and Handling
  • Never apply more than -15 dBm of power into any RF input.
  • Always use at least 30dB attenuation if operating in loopback configuration
Legal Considerations
Sales and Ordering Support
If you have any non­technical questions related to your order, then please contact us by email at [email protected]​, or by phone at +1­408­610­6399 (Monday­Friday, 8 AM 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
Terms and Conditions of Sale
