USRP2
- (EOL – this product is no longer available for sale through Ettus Research)
- 50 MHz of RF bandwidth with 8 bit samples
- 25 MHz of RF bandwidth with 16 bit samples
- Gigabit Ethernet connectivity
- MIMO capable - requires two or more USRP2 devices as motherboard has one daughterboard slot (1 RX + 1 TX connectors)
- Onboard FPGA processing
- FPGA: Xilinx Spartan XC3S2000
- ADCs: 14-bits 100 MS/s
- DACs: 16-bits 400 MS/s
- Ability to lock to external 5 or 10 MHz clock reference
Basic Hardware Setup
FAQ
What are the available resources on the FPGA?
The available resources on the FPGA will vary depending on the code written for it. Based on the 27 March 2012 FPGA code build, the following resources are available:
USRP2 (Xilinx Spartan 3 - XC3S2000 FPGA)
- General Logic
- Memory: 3% free
- DSP Resources: The FPGA does not have DSP resources
Where can I find a compatible SD Card for the USRP2?
Not all SD Cards are compatible with the USRP2; therefore we recommend using the Kingston 2GB SD cards with part number KGS SD2GB as we have found they work reliably. For our customers' convenience, we still stock replacement SD cards available for $10. Please contact [email protected] if you require a replacement SD card.
Proper Care and Handling
- Never apply more than -15 dBm of power into any RF input.
- Always use at least 30dB attenuation if operating in loopback configuration
Technical support for USRP hardware is available through email only. If the product arrived in a nonfunctional state or you require technical assistance, please contact [email protected]. Please allow 24 to 48 hours for response by email, depending on holidays and weekends, although we are often able to reply more quickly than that.
Discussions involving the USRP hardware and the UHD software itself are best addressed through the usrp-users mailing list at http://usrp-users.ettus.com.
Discussions involving the use of GNU Radio with USRP hardware and UHD software are best addressed through the discuss-gnuradio mailing list at https://lists.gnu.org/mailman/listinfo/discussgnuradio.
Discussions involving the use of OpenBTS® with USRP hardware and UHD software are best addressed through the openbts-discuss mailing list at https://lists.sourceforge.net/lists/listinfo/openbtsdiscuss.
The support page on our website is located at https://www.ettus.com/support. The Knowledge Base is located at https://kb.ettus.com.
Legal Considerations
Sales and Ordering Support
If you have any nontechnical questions related to your order, then please contact us by email at [email protected], or by phone at +14086106399 (MondayFriday, 8 AM 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
Terms and Conditions of Sale
