Getting Started with UHD and C++
- 1 Application Note Number
- 2 Revision History
- 3 Abstract
- 4 Overview
- 5 UHD Manual
- 6 Doxygen Documentation
- 7 Including Header Files
- 8 UHD_SAFE_MAIN()
- 9 set_thread_priority_safe()
- 10 Create Variables
- 11 Creating a USRP Object
- 12 Setting Motherboard Clocks
- 13 Selecting Sub Device
- 14 Setting Sample Rate
- 15 Setting Center Frequency
- 16 Setting RF Gain
- 17 Setting IF Filter Bandwidth
- 18 Selecting Antenna
- 19 Full Example
- 20 CMake
- 21 Compile and Install
- 22 Running the Application
- 23 Additional Example Programs
AN-204
| Date | Author | Details |
| 2016-05-01 | Neel Pandeya Nate Temple |
Initial creation |
This AN explains how to write and build C++ programs that use the UHD API.
This Application Note will walk through building a basic C++ program with UHD. This program will initialize, configure the USRP device, set the sample rate, frequency, gain, bandwidth, and select the antenna.
UHD Manual
UHD_SAFE_MAIN()
Create Variables
std::string device_args("addr=192.168.10.2");
std::string subdev("A:0");
std::string ant("TX/RX");
std::string ref("internal");
double rate(1e6);
double freq(915e6);
double gain(10);
double bw(1e6);
//create a usrp device
std::cout << std::endl;
std::cout << boost::format("Creating the usrp device with: %s...") % device_args << std::endl;
uhd::usrp::multi_usrp::sptr usrp = uhd::usrp::multi_usrp::make(device_args);
// Lock mboard clocks
std::cout << boost::format("Lock mboard clocks: %f") % ref << std::endl;
usrp->set_clock_source(ref);
Setting Sample Rate
Setting RF Gain
Selecting Antenna
Full Example
#include <uhd/utils/thread_priority.hpp>
#include <uhd/utils/safe_main.hpp>
#include <boost/program_options.hpp>
#include <boost/format.hpp>
#include <boost/thread.hpp>
#include <iostream>
int UHD_SAFE_MAIN(int argc, char *argv[]) {
uhd::set_thread_priority_safe();
double rate(1e6);
double freq(915e6);
double gain(10);
double bw(1e6);
//always select the subdevice first, the channel mapping affects the other settings
std::cout << boost::format("subdev set to: %f") % subdev << std::endl;
usrp->set_rx_subdev_spec(subdev);
std::cout << boost::format("Using Device: %s") % usrp->get_pp_string() << std::endl;
//set the sample rate
if (rate <= 0.0) {
std::cerr << "Please specify a valid sample rate" << std::endl;
return ~0;
// set sample rate
std::cout << boost::format("Setting RX Rate: %f Msps...") % (rate / 1e6) << std::endl;
usrp->set_rx_rate(rate);
std::cout << boost::format("Actual RX Rate: %f Msps...") % (usrp->get_rx_rate() / 1e6) << std::endl << std::endl;
// set freq
std::cout << boost::format("Setting RX Freq: %f MHz...") % (freq / 1e6) << std::endl;
uhd::tune_request_t tune_request(freq);
usrp->set_rx_freq(tune_request);
std::cout << boost::format("Actual RX Freq: %f MHz...") % (usrp->get_rx_freq() / 1e6) << std::endl << std::endl;
// set the rf gain
std::cout << boost::format("Setting RX Gain: %f dB...") % gain << std::endl;
usrp->set_rx_gain(gain);
std::cout << boost::format("Actual RX Gain: %f dB...") % usrp->get_rx_gain() << std::endl << std::endl;
// set the IF filter bandwidth
std::cout << boost::format("Setting RX Bandwidth: %f MHz...") % (bw / 1e6) << std::endl;
usrp->set_rx_bandwidth(bw);
std::cout << boost::format("Actual RX Bandwidth: %f MHz...") % (usrp->get_rx_bandwidth() / 1e6) << std::endl << std::endl;
// set the antenna
std::cout << boost::format("Setting RX Antenna: %s") % ant << std::endl;
usrp->set_rx_antenna(ant);
std::cout << boost::format("Actual RX Antenna: %s") % usrp->get_rx_antenna() << std::endl << std::endl;
return EXIT_SUCCESS;
CMake
Use the uhd/host/examples/init_usrp/CMakeLists.txt file as template - Add the names of your C++ source files to the add_executable(...) section - Put both modified CMakeLists.txt file and C++ file into an empty folder
Compile and Install
- Create a “build” folder and invoke CMake the usual way:
mkdir build cd build cmake ../ make
[example output]
- Github UHD
