XCVR2450
Revision as of 02:19, 14 May 2016 by Ettus (Talk | contribs) (Legal Considerations)
The XCVR2450 is a high-performance transceiver intended for operation 2.4 GHz and 5.9 GHz range. Filtering on the XCVR2450 provides exceptional selectivity and dynamic range in the intended bands of operation. The typical power output of the XCVR2450 is 100 mW. Example applications include public safety, UNII, ISM, Japanese wireless and UWB development platforms.
The XCVR2450 is a half-duplex transceiver. For full-duplex operation in the 2.4 GHZ range, see the SBX.
The XCVR2450 daughterboard has been revised to improve its specifications and is no longer compatible with the USRP1. For applications requiring an XCVR2450 daughterboard to be used exclusively with the USRP1, please purchase the XCVR2450-U1.
Not Recommended for New Designs. Please consider the CBX, SBX or UBX instead.
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The BasicTX/BasicRX is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the BasicTX/BasicRX can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Technical support for USRP hardware is available through email only. If the product arrived in a non­functional state or you require technical assistance, please contact support@ettus.com. Please allow 24 to 48 hours for response by email, depending on holidays and weekends, although we are often able to reply more quickly than that.
Sales and Ordering Support
If you have any non­-technical questions related to your order, then please contact us by email at orders@ettus.com​, or by phone at +1­408­610­6399 (Monday-Friday, 8 AM - 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
Terms and Conditions of Sale
