SBX
[hide]Device Overview
The SBX is capable of phase coherent operation, and therefore is suitable for MIMO and Phased Array applications.
Hardware Specifications
SBX
- Details
Environmental Specifications
- 0-40 °C
USRP Compatibility
SBX-40
- N or X Series
SBX-120
- X Series only
SBX
Key Component Datasheets
MGA82563 | U1, U5, U4 (1) | |
AS225-313LF | U3, U6 (1) | |
HMC624LP4E | U2, U7 (1) | |
LFCN-5850+ | FL1 (1) | |
PHA-1+ | U8 (1) | |
GVA-84+ | U9 (1) | |
ADL5380ACPZ | U11 (2) | |
ADA4927-2YCPZ | U10 (2) | |
AD8591ARTZ-REEL | U31 (2) | |
NC7WZ04P6X | U26 (3) | |
ADF4350BCPZ | U23 (3); U24 (6) | |
SKY13267-321 | U12 (3) | |
LFCN-1200+ | FL13 (3); FL12 (6) | |
TC1-1-43A+ | T3 (2); T2, T5 (3); T4, T6 (6) | |
LP3878MR-ADJ | U13, U14 (4); U19, U20 (5) | |
NC7WZ04P6X | U15, U16 (4); U21 (5); U27 (6) | |
24LC024 | U17 (4); U22 (5) | |
ADL5375 | U18 (5) | |
SKY13267 | U25 (6) |
Mechanical Info
- Add Drawings
RF Connectors
