LFTX/LFRX
The LFTX daughterboard utilizes two high-speed operational amplifiers to allow transmission from 0-30 MHz. The LFTX is ideal for applications in the HF band, or for applications using an external front end to up-convert and amplify the intermediate signal. The outputs of the LFTX can be processed independently, or as a single I/Q pair. Example applications include HF communications, radios with external front ends and direct signal generation below 30 MHz.
Hardware Specifications
LFRX
- Details
LFTX
- Details
Environmental Specifications
- 0-40 °C
USRP Compatibility
LFRX
- N or X Series
LFTX
- N or X Series
LFRX
LFTX
Key Component Datasheets
| AD813x - verify | U2, U3 (1) | |
| LT3462 | U3 (1) | |
| 24LC025B | EEPROM | U1 (1) |
Mechanical Info
- Add Drawings
RF Connectors
- The LFTX / LFRX daughterboard features female SMA connectors for both the TX and RX connectors.
