N200/N210
- 1 Device Overview
- 2 Key Features
- 3 Compatible Daughterboards
- 4 RF Specifications
- 5 Hardware Specifications
- 6 Clocks and Samples Rates
- 7 Physical Specifications
- 8 Environmental Specifications
- 9 Schematics
- 10 Key Component Datasheets
- 11 Mechanical Info
- 12 FPGA
- 13 Interfaces and Connectivity
- 14 Multiple Device Configuration
- 15 Certifications
- 16 Certificate of Volatility
- 17 Downloads (FPGA images, E310 images, etc.)
- 18 Application Notes
The USRP Network Series offers high-bandwidth, high-dynamic range processing capability. The Gigabit Ethernet interface of the USRP Network Series allows high-speed streaming capability up to 50 MS/s in both directions (8-bit samples). These features, combined with plug-and-play MIMO capability make the USRP Network an ideal candidate for software defined radio systems with demanding performance requirements.
N200
N210
- SBX-40
- UBX-40
- WBX-40
- CBX-40
- LFRX / LFTX
- BasicRX / BasicTX
- TVRX2
- DBSRX2
RF Performance (with WBX)
- Phase Noise 1.8 GHz 10kHz -80 dBc/Hz
- Phase Noise 1.8 GHz 100kHz -100 dBc/Hz
- Phase Noise 1.8 GHz 1MHz -137 dBc/Hz
- Power Output 15 dBm
- IIP3 (@ typ NF) 0 dBm
- Typical Noise Figure 5 dB
N200
- Details
N210
- Details
- FIXME NEEL
Dimensions
22 x 16 x 5 cm
- N200/N210 0-40 °C
N200/N210
| AD9777 | Dual Channel, 16-Bit DAC | U3 (1) |
| ADS62P4X | Dual Channel, 14-Bit ADC | U2 (1) |
| XC3SD3400AFG676 | FPGA | U1 (2,8,9,10,11,12) |
| AD56x3 | U4, U5 (3) | |
| AD9510 | Clock Distribution IC | U9 (4) |
| ET1011C2 | Gigabit Ethernet Transceiver | U12 (6) |
| CY7C1354C | Pipelined SRAM | U19 (7) |
| MAX232 | Drivers/Receiver | U25 (10) |
Mechanical Info
Weight
1.2 kg
FPGA
- Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.4
N200
Device utilization summary:
Selected Device : 3sd1800afg676-5
Number of Slices: 18356 out of 16640 110% (*)
Number of Slice Flip Flops: 20466 out of 33280 61%
Number of 4 input LUTs: 32968 out of 33280 99%
Number used as logic: 28511
Number used as Shift registers: 3945
Number used as RAMs: 512
Number of IOs: 338
Number of bonded IOBs: 331 out of 519 63%
IOB Flip Flops: 342
Number of BRAMs: 41 out of 84 48%
Number of GCLKs: 6 out of 24 25%
Number of DCMs: 1 out of 8 12%
Number of DSP48s: 31 out of 84 36%
N210
Selected Device : 3sd3400afg676-5
Number of Slices: 18349 out of 23872 76%
Number of Slice Flip Flops: 20475 out of 47744 42%
Number of 4 input LUTs: 32986 out of 47744 69%
Number used as logic: 28529
Number of IOs: 338
Number of bonded IOBs: 331 out of 469 70%
IOB Flip Flops: 342
Number of BRAMs: 41 out of 126 32%
Number of DSP48s: 31 out of 126 24%
N200/N210
- Gigabit Ethernet
- [ADD]
N200/N210
