Getting Started with UHD and C++
- 1 Application Note Number
- 2 Revision History
- 3 Abstract
- 4 Overview
- 5 UHD Manual
- 6 Including Header Files
- 7 UHD_SAFE_MAIN()
- 8 set_thread_priority_safe()
- 9 Create Variables
- 10 Creating a USRP Object
- 11 Setting the Motherboard Clocks
- 12 Selecting the Sub Device
- 13 Getting the selected Sub Device
- 14 Setting the Sample Rate
- 15 Getting the Sample Rate
- 16 Setting Center Frequency
- 17 Getting the Center Frequency
- 18 Setting the RF Gain
- 19 Reading the RF Gain
- 20 Setting the IF Filter Bandwidth
- 21 Getting the IF Filter Bandwidth
- 22 Selecting the Antenna
- 23 Getting the Antenna
- 24 Exiting
- 25 Full Example
- 26 CMake
- 27 Compile and Install
- 28 Running the Application
- 29 Additional Example Programs
AN-204
| Date | Author | Details |
| 2016-05-01 | Neel Pandeya Nate Temple |
Initial creation |
This AN explains how to write and build C++ programs that use the UHD API.
This Application Note will walk through building a basic C++ program with UHD. This program will initialize, configure the USRP device, set the sample rate, frequency, gain, bandwidth, and select the antenna.
UHD Manual
The UHD Manual is hosted at http://files.ettus.com/manual/index.html and provides information on how to use the USRP devices and how to use the UHD API to connect to them through your own software. The manual is split into two parts: The device manual, and the UHD/API manual. The first part describes details of Ettus Research devices, motherboards and daughterboards, as well as aspects of using UHD. The second is meant for developers writing UHD-based applications, and includes descriptions of the API, sorted by namespaces, classes, and files.
#include <uhd/utils/thread_priority.hpp>
#include <uhd/utils/safe_main.hpp>
#include <boost/program_options.hpp>
#include <boost/format.hpp>
#include <boost/thread.hpp>
#include <iostream>
UHD_SAFE_MAIN()
Defines a safe wrapper that places a catch-all around main. If an exception is thrown, it prints to stderr and returns.
int UHD_SAFE_MAIN(int argc, char *argv[]) {
Set the scheduling priority on the current thread. Same as set_thread_priority but does not throw on failure.
uhd::set_thread_priority_safe();
Create Variables
std::string device_args("addr=192.168.10.2");
std::string subdev("A:0");
std::string ant("TX/RX");
std::string ref("internal");
double rate(1e6);
double freq(915e6);
double gain(10);
double bw(1e6);
uhd::usrp::multi_usrp::sptr usrp = uhd::usrp::multi_usrp::make(device_args);
Set the clock source for the usrp device. This sets the source for a 10 MHz reference clock. Typical options for source: internal, external, MIMO.
usrp->set_clock_source(ref);
Set the RX frontend specification. The subdev spec maps a physical part of a daughter-board to a channel number. Set the subdev spec before calling into any methods with a channel number. The subdev spec must be the same size across all motherboards. For more details on selecting the Sub Device, see the Specifying the Subdevice section of the UHD Manual.
usrp->set_rx_subdev_spec(subdev)
usrp->get_pp_string()
Set the RX sample rate. The rate is in Samples Per Second.
usrp->set_rx_rate(rate)
Gets the RX sample rate. Returns the rate is in Samples Per Second.
usrp->get_rx_rate()
Create a tune request, with the RF frequency in Hz. Set the RX center frequency.
uhd::tune_request_t tune_request(freq)
usrp->set_rx_freq(tune_request);
Get the RX center frequency. Returns the frequency in Hz.
usrp->get_rx_freq()
Setting the RF Gain
Set the RX gain value for the specified gain element. For an empty name, distribute across all gain elements. Sets the gain in dB.
usrp->set_rx_gain(gain)
Reading the RF Gain
Get the RX gain value for the specified gain element. For an empty name, sum across all gain elements. Returns the gain in dB.
usrp->get_rx_gain()
Set the RX bandwidth on the frontend. Sets the bandwidth in Hz.
usrp->set_rx_bandwidth(bw)
Get the RX bandwidth on the frontend. Returns the bandwidth in Hz.
usrp->get_rx_bandwidth()
Select the RX antenna on the frontend.
usrp->set_rx_antenna(ant)
Getting the Antenna
Get the selected RX antenna on the frontend. Returns the antenna name.
usrp->get_rx_antenna()
Exiting
return EXIT_SUCCESS;
Full Example
#include <iostream>
double rate(1e6);
double freq(915e6);
double gain(10);
double bw(1e6);
//create a usrp device
std::cout << std::endl;
std::cout << boost::format("Creating the usrp device with: %s...") % device_args << std::endl;
// Lock mboard clocks
std::cout << boost::format("Lock mboard clocks: %f") % ref << std::endl;
//always select the subdevice first, the channel mapping affects the other settings
std::cout << boost::format("subdev set to: %f") % subdev << std::endl;
usrp->set_rx_subdev_spec(subdev);
std::cout << boost::format("Using Device: %s") % usrp->get_pp_string() << std::endl;
//set the sample rate
if (rate <= 0.0) {
std::cerr << "Please specify a valid sample rate" << std::endl;
return ~0;
// set sample rate
std::cout << boost::format("Setting RX Rate: %f Msps...") % (rate / 1e6) << std::endl;
usrp->set_rx_rate(rate);
std::cout << boost::format("Actual RX Rate: %f Msps...") % (usrp->get_rx_rate() / 1e6) << std::endl << std::endl;
// set freq
std::cout << boost::format("Setting RX Freq: %f MHz...") % (freq / 1e6) << std::endl;
uhd::tune_request_t tune_request(freq);
std::cout << boost::format("Actual RX Freq: %f MHz...") % (usrp->get_rx_freq() / 1e6) << std::endl << std::endl;
// set the rf gain
std::cout << boost::format("Setting RX Gain: %f dB...") % gain << std::endl;
usrp->set_rx_gain(gain);
std::cout << boost::format("Actual RX Gain: %f dB...") % usrp->get_rx_gain() << std::endl << std::endl;
// set the IF filter bandwidth
std::cout << boost::format("Setting RX Bandwidth: %f MHz...") % (bw / 1e6) << std::endl;
usrp->set_rx_bandwidth(bw);
std::cout << boost::format("Actual RX Bandwidth: %f MHz...") % (usrp->get_rx_bandwidth() / 1e6) << std::endl << std::endl;
// set the antenna
std::cout << boost::format("Setting RX Antenna: %s") % ant << std::endl;
usrp->set_rx_antenna(ant);
std::cout << boost::format("Actual RX Antenna: %s") % usrp->get_rx_antenna() << std::endl << std::endl;
CMake
Use the uhd/host/examples/init_usrp/CMakeLists.txt file as template - Add the names of your C++ source files to the add_executable(...) section - Put both modified CMakeLists.txt file and C++ file into an empty folder
Compile and Install
- Create a “build” folder and invoke CMake the usual way:
mkdir build cd build cmake ../ make
[example output]
- Github UHD
