- 1 Device Overview
- 2 Key Features
- 3 RF Specifications
- 4 Hardware Specifications
- 5 Clocks and Samples Rates
- 6 Physical Specifications
- 8 Schematics
- 9 Key Component Datasheets
- 10 Mechanical Info
- 11 Enclosures
- 12 FPGA
- 13 Interfaces and Connectivity
- 14 Multiple Device Configuration
- 15 Certifications
- 16 Certificate of Volatility
- 17 Downloads
- 18 FAQ
B200
B210
B200mini
B200mini-i
B205mini-i
RF Performance
- Power Output >10dBm
- IIP3 (@ typ NF) -20dBm
- Typical Noise Figure <8dB
- Maximum Input Power: 0 dBm
Performance Data
B200mini / B205mini
B200 / B210
B200
- Current Hardware Revision: 5
- Minimum version of UHD required: 3.8.4
- B200 Rev 5 (AD9364-based board) requires minimum UHD 3.8.4
B210
- Minimum version of UHD required: 3.6.0
B200mini
- Current Hardware Revision: x
- Minimum version of UHD required: 3.9.0
B200mini-i
B205mini-i
- Minimum version of UHD required: 3.9.2
- FIXME NEEL
Dimensions
- B200mini/B205mini 5.0 x 8.4 cm
- B200/B210 9.7 x 15.5 x 1.5 cm
- B200mini 0-40 °C
- B200mini-i 0-45 °C
- B205mini-i 0-45 °C
- B200 0-40 °C
- B210 0-40 °C
B200mini
B210
| Analog Devices AD9364 | RF Transceiver | U1 (2) |
| Analog Devices AD9361 | RF Transceiver | U2 (2,8) |
| Xilinx Spartan-6 Product Page | FPGA | |
| XC6SLX75 / XC6SLX150 | FPGA | U1 (2,3,4,6); PG1 (6); U18B, U18C (7); U18D (8); U18E, U18F (9); U18G, U18H (10) |
| ADF4001 | Frequency Synthesizer | U101 (1) |
| CYUSB3014 | FX3: SuperSpeed USB Controller | U3 (5,6); U13 (5) |
| SKY13317 | Antenna Switch | U801, U810 (8) |
| BD3150L50100A00 | Balun | U802, U808, U809, U815 (8) |
| PGA−102+ | Amplifier | U804, U817 (8) |
| B200mini VXTCXO | VXTCXO (B200mini only) | |
| M9107 | Optional GPSDO (B200/B210 only) | U100 (1) |
Mechanical Info
Weight
- B200mini 24.0 g
- B200/B210 350 g
Drawings
- B200mini Media:B200mini_drawing.png
Enclosures
- Full Steel Enclosure
- Compatible with green USRP B200 and B210 devices (revision 6 or later)
- Front and rear K-Slots for anti-theft protection
FPGA
- Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.4
B200
Device utilization summary:
Selected Device : 6slx75fgg484-3
Slice Logic Utilization:
Number of Slice Registers: 15781 out of 93296 16%
Number of Slice LUTs: 19987 out of 46648 42%
Number used as Logic: 15983 out of 46648 34%
Number used as Memory: 4004 out of 11072 36%
Number used as RAM: 972
Number used as SRL: 3032
Slice Logic Distribution:
Number of LUT Flip Flop pairs used: 24062
Number with an unused Flip Flop: 8281 out of 24062 34%
Number with an unused LUT: 4075 out of 24062 16%
Number of fully used LUT-FF pairs: 11706 out of 24062 48%
Number of unique control sets: 434
IO Utilization:
Number of IOs: 172
Number of bonded IOBs: 155 out of 280 55%
IOB Flip Flops/Latches: 124
Specific Feature Utilization:
Number of Block RAM/FIFO: 144 out of 172 83%
Number using Block RAM only: 144
Number of BUFG/BUFGCTRLs: 4 out of 16 25%
Number of DSP48A1s: 76 out of 132 57%
B210
Selected Device : 6slx150fgg484-3
Number of Slice Registers: 29310 out of 184304 15%
Number of Slice LUTs: 36486 out of 92152 39%
Number used as Logic: 29279 out of 92152 31%
Number used as Memory: 7207 out of 21680 33%
Number used as RAM: 1752
Number used as SRL: 5455
Number of LUT Flip Flop pairs used: 43635
Number with an unused Flip Flop: 14325 out of 43635 32%
Number with an unused LUT: 7149 out of 43635 16%
Number of fully used LUT-FF pairs: 22161 out of 43635 50%
Number of unique control sets: 723
IO Utilization:
Number of IOs: 180
Number of bonded IOBs: 163 out of 338 48%
IOB Flip Flops/Latches: 148
Number of Block RAM/FIFO: 186 out of 268 69%
Number using Block RAM only: 186
Number of DSP48A1s: 152 out of 180 84%
B200mini
Selected Device : 6slx75csg484-3
Number of Slice Registers: 15949 out of 93296 17%
Number of Slice LUTs: 19963 out of 46648 42%
Number used as Logic: 16140 out of 46648 34%
Number used as Memory: 3823 out of 11072 34%
Number used as SRL: 2851
Number of LUT Flip Flop pairs used: 23859
Number with an unused Flip Flop: 7910 out of 23859 33%
Number with an unused LUT: 3896 out of 23859 16%
Number of fully used LUT-FF pairs: 12053 out of 23859 50%
Number of unique control sets: 429
IO Utilization:
Number of IOs: 123
Number of bonded IOBs: 114 out of 328 34%
IOB Flip Flops/Latches: 147
Number of Block RAM/FIFO: 110 out of 172 63%
Number using Block RAM only: 110
Number of BUFG/BUFGCTRLs: 6 out of 16 37%
Number of PLL_ADVs: 1 out of 6 16%
B205mini
Selected Device : 6slx150csg484-3
Number of Slice Registers: 15949 out of 184304 8%
Number of Slice LUTs: 19963 out of 92152 21%
Number used as Logic: 16140 out of 92152 17%
Number used as Memory: 3823 out of 21680 17%
IO Utilization:
Number of IOs: 123
Number of bonded IOBs: 114 out of 338 33%
Number of Block RAM/FIFO: 110 out of 268 41%
Number of DSP48A1s: 76 out of 180 42%
B200/B210/B200mini - USB 3.0
- [ADD]
B200/B210
Downloads
FAQ
This is a list of frequently asked questions on the USRP B200/B210/B200mini. If you have questions that are not answered in this document, please contact us - [email protected].
| 5 Msps | 15.36 Msps | 30.72 Msps | 56 Msps | 61.44 Msps | |
| 1 RX | 1.92 | 2.112 | 2.184 | 2.508 | |
| 2 RX | 2.148 | 2.436 | 2.508 | 2.64 | |
| 1 TX | 2.184 | 2.34 | 2.352 | 2.22 | |
| 2 TX | 2.76 | 2.88 | 2.904 | 2.64 | |
| Full Duplex (1x1) | 2.508 | 2.736 | 2.796 | 3.168 | |
| 2x2 MIMO | 3.252 | 3.588 | 3.672 | 4.11 | 4.092 |
