USRP1
Revision as of 19:54, 15 May 2016 by Ettus (Talk | contribs) (Legal Considerations)
  • (EOL – this product is no longer available for sale through Ettus Research)
  • 16 MHz of RF bandwidth with 8 bit samples
  • 8 MHz of RF bandwidth with 16 bit samples (RX Only)
  • USB 2.0 high speed connectivity
  • MIMO with a single USRP device the motherboard has two daughterboard slots (2 RX + 2 TX connectors)
  • FPGA: Altera Cyclone
  • ADCs: 12-bits 64 MS/s
  • DACs: 14-bits 128 MS/s
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The BasicTX/BasicRX is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the BasicTX/BasicRX can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Sales and Ordering Support
Terms and Conditions of Sale
