BasicTX/BasicRX
Revision as of 23:44, 15 May 2016 by Ettus (Talk | contribs) (→‎Key Component Datasheets)
The BasicRx/BasicTx daughterboards are low-cost daughterboards that provides direct access to the ADC inputs. The boards can accept real-mode signals from 1 to 250 MHz. The BasicRx/BasicTx is ideal for applications using an external front end providing relatively clean signals within operable bandwidth. Wideband transformers couple each RF input to a single channel of the USRP device's ADC. The signals sampled by the ADC are manipulated in the FPGA, and can be processed as two real-mode signals, or a single I-Q pair.
  • 1-250 MHz coverage
  • Real or Complex sampling
Hardware Specifications
BasicRX
  • Minimum version of UHD required: 3.8.0
BasicTX
Environmental Specifications
  • 0-40 °C
USRP Compatibility
BasicRX
  • N or X Series
BasicTX
  • N or X Series
Basic RX
Basic RX Schematics
Basic TX
Basic TX Schematics
24LC025B EEPROM U1 (1)
ADT1−1WT RF Transformer T1 (1); T2 (1)
RF Connectors
  • The BasicTX/RX daughterboard features female SMA connectors for both the RX and TX connectors.
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
