WBX
[hide]Device Overview
The WBX is a wide bandwidth transceiver that provides up to 100 mW of output power and a noise figure of 5 dB. The LO's for the receive and transmit chains operate independently.
The WBX does not provided phase coherent operation, and therefore is not recommended for MIMO and Phased Array applications.
Hardware Specifications
WBX-40
WBX-120
Environmental Specifications
- 0-40 °C
USRP Compatibility
WBX-40
- N or X Series
WBX-120
- X Series only
WBX
Key Component Datasheets
ADA4937 | Ultralow Distortion Differential ADC Driver | U304 (2) |
ADP3336 | High Accuracy Ultralow IQ, 500 mA anyCAP® Adjustable Low Dropout Regulator | U306, U308 (2); U503, U505 (4) |
ADL5387 | 50 MHz to 2 GHz Quadrature Demodulator | U307 (2) |
ADL5385 | 50 MHz to 2200 MHz Quadrature Modulator | U501 (4,5) |
ADF4350 / ADF4351 | Wideband Synthesizer with Integrated VCO Verification needed | U201 (3); U401 (5) |
HMC472LP4 | Attenuator | U302 (2); U504 (4,5) |
MGA82563 | Amplifier | U313 (2) |
24LC024 | EEPROM | U202 (3); U403 (5) |
GVA−84+ | Amplifier | U502 (4) |
RF Connectors
- The WBX daughterboard features female MCX connectors for both the TX/RX and RX2 connectors.
