Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux
AN-445
Date | Author | Details |
2016-05-01 | Neel Pandeya | Initial creation |
This Application Note provides a comprehensive guide for building, installing, and maintaining the open-source toolchain for the USRP (UHD and GNU Radio) from source code on the Linux platform. The Ubuntu and Fedora distributions are specifically discussed. Several other alternate installation methods are also discussed.
http://files.ettus.com/manual/page_build_guide.html#build_instructions_unix
UHD on Linux
UHD is fully supported on Linux, using the GCC compiler, and should work on most major Linux distributions.
Devices
This document applies only to the USRP X300, X310, B200, B210, B200mini, N200, N210 devices. The E310 and E312 devices are embedded devices, and are fundamentally different from the other non-embedded USRP devices, and are not addressed by this document.
Using a Virtual Machine (VM)
UHD may be installed and run within a Virtual Machine (VM), such as VMware and VirtualBox. There are some special issues to address when running UHD within a VM, and these are discussed in a separate Appliaction Note. If you are using VirtualBox, we recommend using version 5.x.
Install Linux
If you already have a recent version of Linux installed, then you may be able to skip this section. If you are starting from scratch, or simply want to start with a fresh new installation of Linux, then please follow the instructions and recommendations in this section.
We suggest that you use either Ubuntu 14.04, Ubuntu 16.04, Fedora 21, Fedora 22, Fedora 23, and that you use a 64-bit architecture, not a 32-bit architecture. There are several re-spins of Ubuntu, such as Xubuntu, Lubuntu, Kubuntu, Linux Mint, all of which should also work. For the purposes of this document, these re-spins can be considered equivalent. Other recent versions of Ubuntu such as 14.10, 15.04, 15.10 should also work. Both Ubuntu and Fedora are known to work well with UHD and GNU Radio.
Download and install Ubuntu, Xubuntu, Linux Mint, or Fedora from the links below. Download the appropriate ISO image, and write it to a USB flash drive. Be sure to verify that the ISO file was not corrupted during the download process by checking the MD5 and/or SHA1 hash.
You can learn more about Ubuntu, Xubuntu, Linux Mint, and Fedora at the links below.
- Wikipedia article on Ubuntu
- Wikipedia article on Xubuntu
- Wikipedia article on Linux Mint
- Wikipedia article on Fedora
There are many tools for writing an ISO image to a USB flash drive. In Linux, you can use the "dd" utility, or the UNetbootin utility. On Ubuntu systems, there is also the Startup Disk Creator utility as well.
- Startup Disk Creator homepage
- Wikipedia article on Startup Disk Creator
- Article about Startup Disk Creator
Be sure to use a USB flash drive with at least 8 GB capacity, and use a USB 3.0 flash drive, not a USB 2.0 flash drive. If you use a slower USB 2.0 flash drive, then the install process will take significantly longer.
Update and Install dependencies
Before building UHD and GNU Radio, you need to make sure that all the dependencies are first installed.
However, before installing any dependencies, you should first make sure that all the packages that are already installed on your system are up-to-date. You can do this from a GUI, or from the command-line, as shown below.
On Ubuntu systems, run:
sudo apt-get update
On Fedora 21 systems, run:
sudo yum update
On Fedora 22 and 23 systems, run:
sudo dnf update
Once the system has been updated, then install the required dependencies for UHD and GNU Radio.
On Ubuntu 15.04, 15.10, 16.04 systems, run:
sudo apt-get -y install git swig cmake doxygen build-essential libboost-all-dev libtool libusb-1.0-0 libusb-1.0-0-dev libudev-dev libncurses5-dev libfftw3-bin libfftw3-dev libfftw3-doc libcppunit-1.13-0 libcppunit-dev libcppunit-doc ncurses-bin cpufrequtils python-numpy python-numpy-doc python-numpy-dbg python-scipy python-docutils qt4-bin-dbg qt4-default qt4-doc libqt4-dev libqt4-dev-bin python-qt4 python-qt4-dbg python-qt4-dev python-qt4-doc python-qt4-doc libqwt6 libfftw3-bin libfftw3-dev libfftw3-doc ncurses-bin libncurses5 libncurses5-dev libncurses5-dbg libfontconfig1-dev libxrender-dev libpulse-dev swig g++ automake autoconf libtool python-dev libfftw3-dev libcppunit-dev libboost-all-dev libusb-dev libusb-1.0-0-dev fort77 libsdl1.2-dev python-wxgtk2.8 git-core libqt4-dev python-numpy ccache python-opengl libgsl0-dev python-cheetah python-mako python-lxml doxygen qt4-default qt4-dev-tools libusb-1.0-0-dev libqwt5-qt4-dev libqwtplot3d-qt4-dev pyqt4-dev-tools python-qwt5-qt4 cmake git-core wget libxi-dev gtk2-engines-pixbuf r-base-dev python-tk liborc-0.4-0 liborc-0.4-dev libasound2-dev python-gtk2 libzmq libzmq-dev libzmq1 libzmq1-dev python-requests python-sphinx comedi-dev python-zmq
On Ubuntu 14.04 and 14.10 systems, run:
sudo apt-get -y install git swig cmake doxygen build-essential libboost-all-dev libtool libusb-1.0-0 libusb-1.0-0-dev libudev-dev libncurses5-dev libfftw3-bin libfftw3-dev libfftw3-doc libcppunit-1.13-0 libcppunit-dev libcppunit-doc ncurses-bin cpufrequtils python-numpy python-numpy-doc python-numpy-dbg python-scipy python-docutils qt4-bin-dbg qt4-default qt4-doc libqt4-dev libqt4-dev-bin python-qt4 python-qt4-dbg python-qt4-dev python-qt4-doc python-qt4-doc libfftw3-bin libfftw3-dev libfftw3-doc ncurses-bin libncurses5 libncurses5-dev libncurses5-dbg libfontconfig1-dev libxrender-dev libpulse-dev swig g++ automake autoconf libtool python-dev libfftw3-dev libcppunit-dev libboost-all-dev libusb-dev libusb-1.0-0-dev fort77 libsdl1.2-dev python-wxgtk2.8 git-core libqt4-dev python-numpy ccache python-opengl libgsl0-dev python-cheetah python-mako python-lxml doxygen qt4-default qt4-dev-tools libusb-1.0-0-dev libqwt5-qt4-dev libqwtplot3d-qt4-dev pyqt4-dev-tools python-qwt5-qt4 cmake git-core wget libxi-dev gtk2-engines-pixbuf r-base-dev python-tk liborc-0.4-0 liborc-0.4-dev libasound2-dev python-gtk2 libzmq1 libzmq1-dev libzmq libzmq-dev python-requests python-sphinx
sudo yum -y groupinstall "Engineering and Scientific" "Development Tools" "Software Development Tools" "C Development Tools and Libraries"
sudo yum -y install fftw-devel cppunit-devel wxPython-devel boost-devel alsa-lib-devel numpy gsl-devel python-devel pygsl python-cheetah python-mako python-lxml PyOpenGL qt-devel qt qt4 qt4-devel PyQt4-devel qwt-devel qwtplot3d-qt4-devel libusbx-devel cmake git wget python-docutils cppzmq-devel PyQwt PyQwt-devel qwt-devel gtk2-engines xmlrpc-c-"*" tkinter orc orc-devel python-sphinx SDL-devel swig zeromq2-devel python-zmq comedilib comedilib-devel thrift-devel python-thrift scipy
sudo dnf -y groupinstall "Engineering and Scientific" "Development Tools" "Software Development Tools" "C Development Tools and Libraries"
sudo dnf -y install fftw-devel cppunit-devel wxPython-devel boost-devel alsa-lib-devel numpy gsl-devel python-devel pygsl python-cheetah python-mako python-lxml PyOpenGL qt-devel PyQt4-devel qwt-devel qwtplot3d-qt4-devel libusbx-devel cmake python-docutils PyQwt PyQwt-devel gtk2-engines xmlrpc-c-"*" tkinter orc-devel python-sphinx SDL-devel swig perl-ZMQ-LibZMQ2 perl-ZMQ-LibZMQ2 zeromq zeromq-devel python-requests gcc-c++ doxygen zeromq-ada-devel cppzmq-devel perl-ZeroMQ amavisd-new-zeromq amavisd-new-snmp-zeromq php-zmq python-zmq czmq uwsgi-logger-zeromq comedilib comedilib-devel pygtk2 ncurses-"*" thrift-devel python-thrift scipy
After installing the dependencies, you should reboot the system.
If the installation of the dependencies completes without any errors, then you can proceed to build and install UHD and GNU Radio.
Installing UHD from source code
UHD is open-source, and is hosted on GitHub. You can browse the code online at the link below, which points to version 3.9.4, which is the the latest release at the time of this writing.
There are several good reasons to build GNU Radio from source code, especially for doing development and prototyping. It it enables an easy way to customize the location of the installation, and to install multiple UHD versions in parallel, and switch between them. It also provides much more flexibility in upgrading and downgrading versions, and allows the user to modify the code and create customized versions, which could possibly include a patch or other bug-fix.
To build UHD from source code, clone the GitHub repository, check out a branch or tagged release of the repository, and build and install. Please follow the steps below. Make sure that no USRP device is connected to the system at this point.
First, make a folder to hold the repository.
cd $HOME
mkdir workarea-uhd
cd workarea-uhd
Next, clone the repository.
git clone https://github.com/EttusResearch/uhd
Next, go into the repository and chcek out the desired UHD version.
cd uhd
git checkout release_003_009_004
Next, create a build folder within the repository.
cd host
mkdir build
cd build
Next, invoke CMake to create the Makefiles.
cmake ../
Next, run Make to build UHD.
make
Next, you can optionally run some basic tests to verify that the build process completed properly.
make test
Next, install UHD, using the default install prefix, which will install UHD under the /usr/local/lib folder. You need to run this as root due to the permissions on that folder.
sudo make install
Next, update the system's shared library cache.
sudo ldconfig
Finally, make sure that the LD_LIBRARY_PATH
environment variable is defined and includes the folder under which UHD was installed. Most commonly, you can add the line below to the end of your $HOME/.bashrc
file:
export LD_LIBRARY_PATH=/usr/local/lib
If the LD_LIBRARY_PATH
environment variable is already defined with other folders in your $HOME/.bashrc
file, then add the line below to the end of your $HOME/.bashrc
file to preserve the current settings.
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/lib
For this change to take effect, you will need to close the current terminal window, and open a new terminal.
At this point, UHD should be installed and ready to use. You can quickly test this, with no USRP device attached, by running uhd_find_devices
. You should see something similar to the following.
linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.009.002-0-gf18abe54 No UHD Devices Found
Installing GNU Radio from source code
As with UHD, GNU Radio is open-source and is hosted on GitHub. You can browse the code online at the link below, which points to version 3.7.9.2, which is the the latest release at the time of this writing.
As with UHD, there are several good reasons to build GNU Radio from source code, especially for doing development and prototyping. It it enables an easy way to customize the location of the installation, and to install multiple GNU Radio versions in parallel, and switch between them. It also provides much more flexibility in upgrading and downgrading versions, and allows the user to modify the code and create customized versions, which could possibly include a patch or other bug-fix.
Similar to the process for UHD, to build GNU Radio from source code, clone the GitHub repository, check out a branch or tagged release of the repository, and build and install. Please follow the steps below. Make sure that no USRP device is connected to the system at this point.
cd $HOME
mkdir workarea-gnuradio
cd workarea-gnuradio
git clone --recursive https://github.com/gnuradio/gnuradio
Next, go into the repository and chcek out the desired GNU Radio version.
cd gnuradio
git checkout v3.7.9.2
mkdir build
cd build
cmake ../
make
make test
Next, install GNU Radio, using the default install prefix, which will install GNU Radio under the /usr/local/lib folder. You need to run this as root due to the permissions on that folder.
sudo make install
Finally, update the system's shared library cache.
sudo ldconfig
At this point, GNU Radio should be installed and ready to use. You can quickly test this, with no USRP device attached, by running the following quick tests.
gnuradio-config-info --version gnuradio-config-info --prefix
You can try launching the GNU Radio Companion (GRC) tool, a visual tool for building and running GNU Radio flowgraphs.
gnuradio-companion
If "gnuradio-companion" does not start and complains about the PYTHONPATH
environment variable, then you may have to set this in your $HOME/.bashrc
file, as shown below.
export PYTHONPATH=/usr/local/lib/python2.7/dist-packages
Configuring USB
On Linux, udev handles USB plug and unplug events. The following commands install a udev rule so that non-root users may access the device. This step is only necessary for devices that use USB to connect to the host computer, such as the B200, B210, and B200mini. This setting should take effect immediately and does not require a reboot or logout/login. Be sure that no USRP device is connected via USB when running these commands.
cd $HOME/workarea-uhd/uhd/host/utils sudo cp uhd-usrp.rules /etc/udev/rules.d/ sudo udevadm control --reload-rules sudo udevadm trigger
