BasicTX/BasicRX
The BasicRx/BasicTx daughterboards are low-cost daughterboards that provides direct access to the ADC inputs. The boards can accept real-mode signals from 1 to 250 MHz. The BasicRx/BasicTx is ideal for applications using an external front end providing relatively clean signals within operable bandwidth. Wideband transformers couple each RF input to a single channel of the USRP device's ADC. The signals sampled by the ADC are manipulated in the FPGA, and can be processed as two real-mode signals, or a single I-Q pair.
Hardware Specifications
BasicRX
BasicTX
Environmental Specifications
- 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
USRP Compatibility
BasicRX
- N or X Series
BasicTX
- N or X Series
Basic RX
Basic TX
Key Component Datasheets
24LC025B | EEPROM | U1 (1); U52 (1) |
ADT1−1WT | RF Transformer | T1 (1); T2 (1); T50 (1); T51 (1) |
RF Connectors
- The BasicTX/RX daughterboard features female SMA connectors for both the RX and TX connectors.
