CBX
The CBX is a full-duplex, wideband transceiver that covers a frequency band from 1.2 GHz to 6 GHz with a instantaneous bandwidth of 40 MHz or 120 MHz. The CBX can serve a wide variety of application areas, including WiFi research, cellular base stations, cognitive radio research, and RADAR.
The CBX does not provided phase coherent operation, and therefore is not recommended for MIMO and Phased Array applications.
Hardware Specifications
CBX
Environmental Specifications
- 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
USRP Compatibility
CBX-40
- N or X Series
CBX-120
- X Series only
CBX
Key Component Datasheets
| VMMK-3603 | Low Noise Amplifier | U1, U5 (1) |
| AS225-313LF | SPDT Switch | U3, U6 (1) |
| HMC624LP4E | ATTENUATOR | U7, U2 (1) |
| MGA82563 | Amplifier | U4 (1) |
| GVA-84+ | Amplifier | U9 (1) |
| PHA-1+ | Amplifier | U8 (1) |
| ADL5380ACPZ | Quadrature Demodulator | U11 (2) |
| ADA4927-2YCPZ | Differential ADC Driver | U10 (2) |
| AD8591ARTZ-REEL | Amplifiers | U31 (2) |
| NC7WZ04P6X | Dual Inverter | U26 (3); U15, U16 (4); U21 (5); U27 (6) |
| MAX2870ETJ+ | Fractional/Integer-N Synthesizer | U23 (3); U24 (6) |
| SKY13267-321 | Diversity Switch | U12 (3); U25 (6) |
| LFCN-2000+ | Low Pass Filter | FL13 (3); FL12 (6) |
| LP3878MR-ADJ | Voltage Regulator | U13, U14 (4); U19, U20 (5) |
| 24LC024 | EEPROM | U17 (4); U22 (5) |
| ADL5375-05 | Quadrature Modulator | U18 (5) |
RF Connectors
- The CBX daughterboard features female SMA connectors for both the TX/RX and RX2 connectors.
