XCVR2450
Revision as of 13:23, 8 June 2016 by Ettus (Talk | contribs) (Proper Care and Handling)
The XCVR2450 is a high-performance transceiver intended for operation 2.4 GHz and 5.9 GHz range. Filtering on the XCVR2450 provides exceptional selectivity and dynamic range in the intended bands of operation. The typical power output of the XCVR2450 is 100 mW. Example applications include public safety, UNII, ISM, Japanese wireless and UWB development platforms.
The XCVR2450 is a half-duplex transceiver. For full-duplex operation in the 2.4 GHZ range, see the SBX.
The XCVR2450 daughterboard has been revised to improve its specifications and is no longer compatible with the USRP1. For applications requiring an XCVR2450 daughterboard to be used exclusively with the USRP1, please purchase the XCVR2450-U1.
Not Recommended for New Designs. Please consider the CBX, SBX or UBX instead.
Frequency Range
  • Low Band: 2.4-2.5 GHz
  • High Band: 4.9-6.0 GHz
All Ettus Research products are individually tested before shipment. The XCVR2450 is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the XCVR2450 can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Legal Considerations
Sales and Ordering Support
Terms and Conditions of Sale
