USRP1
Revision as of 14:27, 8 June 2016 by Ettus (Talk | contribs) (Proper Care and Handling)
  • (EOL – this product is no longer available for sale through Ettus Research)
  • 16 MHz of RF bandwidth with 8 bit samples
  • 8 MHz of RF bandwidth with 16 bit samples (RX Only)
  • USB 2.0 high speed connectivity
  • MIMO with a single USRP device the motherboard has two daughterboard slots (2 RX + 2 TX connectors)
  • FPGA: Altera Cyclone
  • ADCs: 12-bits 64 MS/s
  • DACs: 14-bits 128 MS/s
All Ettus Research products are individually tested before shipment. The USRP1 is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the USRP1 can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Legal Considerations
Sales and Ordering Support
Terms and Conditions of Sale
