USRP2
Revision as of 14:28, 8 June 2016 by Ettus (Talk | contribs) (→‎Proper Care and Handling)
  • (EOL – this product is no longer available for sale through Ettus Research)
  • 50 MHz of RF bandwidth with 8 bit samples
  • 25 MHz of RF bandwidth with 16 bit samples
  • Gigabit Ethernet connectivity
  • MIMO capable - requires two or more USRP2 devices as motherboard has one daughterboard slot (1 RX + 1 TX connectors)
  • Onboard FPGA processing
  • FPGA: Xilinx Spartan XC3S2000
  • ADCs: 14-bits 100 MS/s
  • DACs: 16-bits 400 MS/s
  • Ability to lock to external 5 or 10 MHz clock reference
FAQ
What are the available resources on the FPGA?
The available resources on the FPGA will vary depending on the code written for it. Based on the 27 March 2012 FPGA code build, the following resources are available:
USRP2 (Xilinx Spartan 3 - XC3S2000 FPGA)
  • General Logic
  • Memory: 3% free
  • DSP Resources: The FPGA does not have DSP resources
Where can I find a compatible SD Card for the USRP2?
Not all SD Cards are compatible with the USRP2; therefore we recommend using the Kingston 2GB SD cards with part number KGS SD2GB as we have found they work reliably. For our customers' convenience, we still stock replacement SD cards available for $10. Please contact [email protected] if you require a replacement SD card.
All Ettus Research products are individually tested before shipment. The USRP2 is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the USRP2 can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Legal Considerations
Sales and Ordering Support
Terms and Conditions of Sale
