WBX
[hide]- 1 Device Overview
- 2 Key Features
- 4 RF Specifications
- 5 Hardware Specifications
- 7 USRP Compatibility
- 8 Schematics
- 9 Key Component Datasheets
- 10 RF Connectors
- 11 Certifications
- 12 Certificate of Volatility
- 13 RF Performance Data
- 14 Downloads
The WBX is a wide bandwidth transceiver that provides up to 100 mW of output power and a noise figure of 5 dB. The LO's for the receive and transmit chains operate independently.
The WBX provides phase coherent operation, although with a 180-degree ambiguity, which must be calibrated out in the application. For phase-coherent applications, Ettus Research recommends the SBX with the N200/N210 or the SBX or UBX with the X300/X310.
Features
Antennas
Transmit: TX/RX
Receive: TX/RX or RX2
- Note: The user may set the receive antenna to be TX/RX or RX2. However, when using a WBX board in full-duplex mode, the receive antenna will always be set to RX2, regardless of the settings.
Gains
- Transmit Gains: PGA0, Range: 0-25dB
Bandwidths
- WBX: 40 MHz, RX & TX
- WBX-120: 120 MHz, RX & TX
Sensors
Freq Range
- 50MHz - 2.2GHz
Noise Figure
- 2 - 4 dB @ (50MHz ~ 1.2GHz)
- 4 - 8 dB @ (1.2GHz ~ 2.2GHz)
RX IIP3 (Max)
- 10 - 18 dBm
RX IQ Imbalance
- -30 dBc
TX Power (Max)
- 18 - 20 dBm @ (50MHz ~ 1.4 GHz)
- 12 - 18dBm @ (1.4GHz ~ 2.2 GHz)
TX OIP3
- 30 - 32 dBm @ (50MHz ~ 800MHz)
- 25 - 30 dBm @ (800MHz ~ 2.2GHz)
TX IQ Imbalance
- -30 dBc @ (50MHz ~ 1.9GHz)
- - 24 dBc @ (1.9GHz ~ 2.2GHz)
WBX-40
WBX-120
- 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
USRP Compatibility
WBX-40
- N or X Series
WBX-120
- X Series only
WBX
ADA4937 | Ultralow Distortion Differential ADC Driver | U304 (2) |
ADP3336 | High Accuracy Ultralow IQ, 500 mA anyCAP® Adjustable Low Dropout Regulator | U306, U308 (2); U503, U505 (4) |
ADL5387 | 50 MHz to 2 GHz Quadrature Demodulator | U307 (2) |
ADL5385 | 50 MHz to 2200 MHz Quadrature Modulator | U501 (4,5) |
ADF4350 / ADF4351 | Wideband Synthesizer with Integrated VCO | U201 (3); U401 (5) |
HMC472LP4 | Attenuator | U302 (2); U504 (4,5) |
MGA82563 | Amplifier | U313 (2) |
24LC024 | EEPROM | U202 (3); U403 (5) |
GVA−84+ | Amplifier | U502 (4) |
RF Connectors
- The WBX daughterboard features female MCX connectors for both the TX/RX and RX2 connectors.
