BasicTX/BasicRX
[hide]Device Overview
The BasicRX/BasicTX daughterboards are low-cost daughterboards that provides direct access to the ADC inputs. The boards can accept real-mode signals from 1 to 250 MHz. The BasicRX/BasicTX is ideal for applications using an external front end providing relatively clean signals within operable bandwidth. Wideband transformers couple each RF input to a single channel of the USRP device's ADC. The signals sampled by the ADC are manipulated in the FPGA, and can be processed as two real-mode signals, or a single I-Q pair.
Daughterboard Specifications
Frontends
BasicRX
The BasicRX has 4 frontends:
- Frontend A: real signal on antenna RXA
- Frontend B: real signal on antenna RXB
- Frontend AB: quadrature frontend using both antennas (IQ)
- Frontend BA: quadrature frontend using both antennas (QI)
BasicTX
The BasicTX has 4 frontends:
- Frontend A: real signal on antenna TXA
- Frontend B: real signal on antenna TXB
Gains
BasicRX
- The BasicRX has no tunable elements or programmable gains. Through the magic of aliasing, you can down-convert signals greater than the Nyquist rate of the ADC.
BasicTX
- The BasicTX has no tunable elements or programmable gains. Through the magic of aliasing, you can up-convert signals greater than the Nyquist rate of the DAC.
Bandwidths
BasicRX
- For Real-Mode (A or B frontend): 250 MHz
- For Complex (AB or BA frontend): 500 MHz
BasicTX
Hardware Specifications
BasicRX
BasicTX
Environmental Specifications
- 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
USRP Compatibility
BasicRX
- N or X Series
BasicTX
- N or X Series
Basic RX
Basic TX
Key Component Datasheets
24LC025B | EEPROM | U1 (1); U52 (1) |
ADT1−1WT | RF Transformer | T1 (1); T2 (1); T50 (1); T51 (1) |
Mechanical Information
Drawings
- BasicRX - File:cu ettus-cca-basic-rx.pdf
RF Connectors
- The BasicTX/RX daughterboard features female SMA connectors for both the RX and TX connectors.
