BasicTX/BasicRX
Revision as of 19:03, 27 July 2016 by Ettus (Talk | contribs) (Drawings)
The BasicRX/BasicTX daughterboards are low-cost daughterboards that provides direct access to the ADC inputs. The boards can accept real-mode signals from 1 to 250 MHz. The BasicRX/BasicTX is ideal for applications using an external front end providing relatively clean signals within operable bandwidth. Wideband transformers couple each RF input to a single channel of the USRP device's ADC. The signals sampled by the ADC are manipulated in the FPGA, and can be processed as two real-mode signals, or a single I-Q pair.
  • 1-250 MHz coverage
  • Real or Complex sampling
Daughterboard Specifications
Frontends
BasicRX
The BasicRX has 4 frontends:
  • Frontend A: real signal on antenna RXA
  • Frontend B: real signal on antenna RXB
  • Frontend AB: quadrature frontend using both antennas (IQ)
  • Frontend BA: quadrature frontend using both antennas (QI)
BasicTX
The BasicTX has 4 frontends:
  • Frontend A: real signal on antenna TXA
  • Frontend B: real signal on antenna TXB
Gains
BasicRX
  • The BasicRX has no tunable elements or programmable gains. Through the magic of aliasing, you can down-convert signals greater than the Nyquist rate of the ADC.
BasicTX
  • The BasicTX has no tunable elements or programmable gains. Through the magic of aliasing, you can up-convert signals greater than the Nyquist rate of the DAC.
Bandwidths
BasicRX
  • For Real-Mode (A or B frontend): 250 MHz
  • For Complex (AB or BA frontend): 500 MHz
BasicTX
Hardware Specifications
BasicRX
  • Minimum version of UHD required: 3.8.0
BasicTX
Environmental Specifications
  • 0-40 °C
Operating Humidity Range
  • 10% to 90% non-condensing
USRP Compatibility
BasicRX
  • N or X Series
BasicTX
  • N or X Series
Basic RX
Basic RX Schematics
Basic TX
Basic TX Schematics
Key Component Datasheets
24LC025B EEPROM U1 (1); U52 (1)
ADT1−1WT RF Transformer T1 (1); T2 (1); T50 (1); T51 (1)
Mechanical Information
Drawings
RF Connectors
  • The BasicTX/RX daughterboard features female SMA connectors for both the RX and TX connectors.
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
