Ettus USRP E300 Embedded Family Getting Started Guides
Revision as of 12:27, 11 October 2016 by Ettus (Talk | contribs)
Kit Contents
E310
  • E310 USRP
  • Power supply
  • 2x SMB-to-SMA adapter
  • 1 Gigabit Ethernet cable
  • USB2-to-microUSB cable
  • Imaged microSD card
  • Getting started guide
E312
  • E312 USRP
  • Power supply
E313
  • Protective caps for input ports
  • Surface mounting accessory
  • Pole mounting accessory
  • End conduit interface for USB devices
  • Waterproof sleeve for DC power connector
  • Waterproof sleeve for PoE (RJ45) connector
  • Torx T-20 key
  • Mounting accessory assembly guide
The USRP E313 is a fully assembled device that includes an USRP E310.
You Will Need
  • A host computer with an available USB 2.0 or 3.0 port
Proper Care and Handling
Never apply more than 0 dBm of power into any RF input.
In order to use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes. See the Hardware Specifications section of the USRP Embedded Series Hardware Resources for additional details on which version of the USRP Hardware Driver, UHD, is required. It is recommended to use the latest stable version of UHD that is available.
Powering On the Hardware
Connecting the USRP power supply to the devices will cause the unit to turn on and boot­up. If this is the first time powering on the device, allow the battery to fully charge before disconnecting the AC power source. Once the device has completed the boot process, you are ready to start using the device over your preferred method of connectivity (Serial Console, Network, or USB peripherals)!
Turning the Device Off/On
You can also power the device on and off by pressing the power button. To power the device off, hold the power button down until the button’s LED turns off (this will take a couple of seconds). To turn the device on, hold down the power button until the LED turns on.
   shutdown ­-h now
Serial Console Connectivity
The easiest way to first communicate with your E31x device is by using the USB Serial Console. Connect a micro­USB cable to the Serial Console port on the E31x and connect the other end to a PC. The console will appear as an “FTDI Serial Device” ­ thus, it will likely appear as a ttyUSB device in Linux or a COM port on Windows. In Windows, you will need to edit the properties of the device in ‘Device Manager’ and ‘Enable VCP’. On the PC, open a serial terminal to the E31x using the following parameters: B​aud Rate:​115200, D​ata:​8­bit, P​arity: None, S​top:​1­bit, F​low Control:​None.
On Linux, the following command will typically handle the serial connection:
   sudo screen /dev/ttyUSB0 115200
You may have to change the device name.
For additional information about using the serial console and instructions for communicating with the device over other methods (such as connecting with SSH over the network or using and LCD screen, keyboard, and mouse), please refer to the UHD Manual online: http://files.ettus.com/manual/page_usrp_e3x0.html
Network Connectivity
By default, the E31x device will run a DHCP client on its 1 Gigabit Ethernet port. Assuming your network resolves hostnames (depends on your routers / switches), if you connect the device to your network, you should see it appear with the hostname e​ttus­e300.​You can then access the device over SSH.
If the hostname does not resolve, you can discover the IP address by logging into the device over the serial connection, or checking your network’s DHCP tables.
Once you have logged in to the device, you can reconfigure the network settings (e.g., you could configure it for a static IP address, if you wish).
Logging In
When you first log in to the device, the user is ‘root’ and the password is empty (no password).
Example Programs
The UHD driver includes several example programs, which may serve as test programs or the basis for your application program. These example programs are already installed on the E31x device, and the source code can be obtained from the UHD repository on GitHub at: https://github.com/EttusResearch/uhd/tree/master/host/examples
Test and Verify the Operation of the USRP
You can quickly verify the operation of your USRP E31x by running the rx_ascii_art_dft UHD example program. The rx_ascii_art_dft utility is a simple console ­based, real­time FFT display tool. It is not graphical in nature, so it can be easily run over an SSH connection within a terminal window, and does not need any graphical capability, such as X Windows, to be installed. It can also be run over a serial console connection, although this is not recommended, as the formatting may not render correctly.
You can run a simple test of the E31x device by connecting an antenna and observing the spectrum of a commercial FM radio station in real­time. Please follow the steps listed below.
1. Attach an antenna to the RX2­A antenna port of the E31x.
2. Log into the E31x from an external host computer over Ethernet using an SSH client.
3. At a terminal prompt running on the E31x, run:
   /usr/lib/uhd/examples/rx_ascii_art_dft ­­--freq 88.1e6 ­­--rate 400e3 ­­--gain 30 ­­--ref­-lvl ­-30
4. Modify the command­line argument "freq" ​above to specify a tuning frequency for a strong local FM radio station.
5. You should see a real­time FFT display of 400 KHz of spectrum, centered at the specified tuning frequency.
6. Type "Q" or Ctrl­-C to stop the program and to return to the Linux command line.
7. You can adjust the size of your terminal window and then re­run the command to enlarge or shrink the FFT display.
8. You can run with the "​­­help"​option to see a description of all available command­line options.
Additional information is available at the Verifying the Operation of the USRP Using UHD and GNU Radio Application Note.
Battery (E312 Only)
The USRP E312 is equipped with an integrated 3.7V, 3200mAh lithium­ion battery cell. After unboxing the USRP E312 , plug in the power adapter to an AC power source and fully charge the battery. This process with take approximately 2 hours. Do not leave the USRP E312 unit plugged in for more than 24 hours.
The status LED in the power button indicates the power and charge status of the battery:
Off: Indicates device is off and not charging.
  • Slow Blinking Green: Indicates device is off and charging.
  • Fast Blinking Green: Indicates device is on and charging.
  • Solid Green: Indicates device is on and not charging (Battery is finished charging).
  • Solid Orange: Indicates device is on and discharging.
  • Fast Blinking Orange: Indicates device is on, discharging, and charge is below 10% charge.
  • Fast Blinking Red: Indicates an error code:
  1. Low Voltage Error
  2. Regulator Low Voltage Error
  3. FPGA Power Error
  4. DRAM Power Error
  5. 1.8V Power Rail Error
  6. 3.3V Power Rail Error
  7. Daughterboard / TX Power Error
  8. Charger Error
  9. Charger Temperature Error
  10. Battery Low Error
  11. Fuel Gauge Temperature Error
  12. Global (Enclosure) Temperature Error
The battery life of the USRP E312 in idle mode is approximately 5 1/2 hours. The battery will enable the USRP E312 to operate for approximately 2 hours 20 minutes, when transmitting and receiving on both channels (2x2 MIMO), with maximum gain settings, at 5 GHz center frequency, and 1 MS/s sample rate. When the power button status LED is in the “Fast Blinking Orange” mode, plug the USRP E312 into an AC power source as soon as possible to recharge the battery.
If the power button status LED indicates a “Low Voltage Error” (codes 1, 2, 3, 4, 5, 6, 7) or a “Battery Low Error” (code 10), plug the USRP E312 into an AC power source as soon as possible to recharge the battery.
When the power button status LED indicates at “Temperature Error” or “Charger Error” (codes 8, 9, 11, or 12), power off the USRP E312 unit and allow it to cool down to room temperature. Then, plug in the USRP E312 to and AC power source and fully charge the battery.
If error codes persist after cooling down and/or recharging the USRP E312 , please contact [email protected]
Battery Calibration Procedure
In order for the battery gauge to give a usable indication of remaining charge it needs to be calibrated. The procedure for calibration is as follows:
  1. Completely charge the battery.
  2. Type: ​echo 3200000 >/sys/class/power_supply/BAT/charge_now
  3. Unplug AC power.
  4. Replug AC power, and wait until charging completes.
Battery Safety Information
To ensure proper use of the battery, please read the the battery specification sheet. This document is provided at the Ettus Research website at: http://files.ettus.com/e3x2_battery/e3x2_battery_spec_sheet.pdf
Because batteries utilize a chemical reaction, battery performance will deteriorate over time even if stored for a long period of time without being used. In addition, if the various usage conditions such as charge, discharge, ambient temperature, etc. are not maintained within the specified ranges, the life expectancy of the battery may be shortened or the device in which the battery is used may be damaged by electrolyte leakage.
Handling
  • Do not expose the battery to flame or dispose of it in a fire.
  • Do not put the battery in a charger or equipment with the wrong terminals connected.
  • Do not short circuit the battery.
  • Avoid excessive physical shock or vibration.
  • Do not disassemble or deform the battery.
  • Do not immerse in water.
  • Do not use the battery mixed with other different make, type, or model batteries.
  • Keep out of the reach of children.
  • Do not use the battery if it appears damaged.
Charge and Discharge
  • Always charge the battery while it is installed in the USRP E312 and only use the DC power supply provided in the USRP E312 kit.
  • Do not leave the battery charging for longer than 24 hours.
  • Never use a modified or damaged USRP E312 DC power supply to charge the battery.
Storage
  • Store the battery in a cool, dry, and well­-ventilated area.
Disposal
  • Regulations vary for different countries. Dispose of the battery in accordance with local regulations.
Legal Considerations
Sales and Ordering Support
Terms and Conditions of Sale
