Ettus USRP E300 Embedded Family Hardware Resources
Revision as of 13:32, 11 October 2016 by Ettus (Talk | contribs) (→‎E310)
The USRP E310 offers a portable stand-alone SDR platform designed for field deployment. The flexible 2x2 MIMO AD9361 transceiver from Analog Devices provides up to 56 MHz of instantaneous bandwidth and spans frequencies from 70 MHz – 6 GHz to cover multiple bands of interest.
E310
  • Xilinx Zynq 7020 SoC: 7 Series FPGA with ARM Cortex A9 667 MHz (SG1) or 866 MHz (SG3) dual-core processor
  • 2x2 MIMO transceiver
  • Up to 10 MS/s sample data transfer rate to ARM processor
  • RX, TX filter banks
  • Integrated GPS receiver
  • 9-axis inertial measurement unit
  • RF Network on Chip (RFNoC™) FPGA development framework support
E312
  • Battery Operated
  • Xilinx Zynq 7020 SoC: 7 Series FPGA with ARM Cortex A9 866 MHz dual-core processor
E313
  • Rugged and weatherproof for outdoor deployment
  • Fully assembled IP67-rated enclosure with USRP E310 inside
  • Extensive environmental testing
  • Power over Ethernet (PoE) with surge and lightning protection
Daughterboard Specifications
E310 MIMO XCVR board
Tuning
Gains
LO lock status
// assumes 'usrp' is a valid uhd::usrp::multi_usrp::sptr instance
// get status for rx frontend
usrp->get_rx_sensor("lo-locked");
// get status for tx frontend
usrp->get_tx_sensor("lo-locked");
Filter and Antenna Switches
Source code related to controlling the filter band and antenna switches resides in e300_impl.c. Specifically, refer to methods e300_impl::_update_bandsel, e300_impl::_update_atrs, e300_impl::_update_gpio, and e300_impl::_update_enables. Generally, these methods set the switches depending on the state of transmit and receive streams.
The following sections provide switch setting tables for antenna and filter selection for frontends A & B receive and transmit paths. For futher details refer to the schematics.
Side A Filter and Antenna Switches
Receive
RX Port RX Filter (MHz) VCTXRX2_V1,V2 VCRX2_V1,V2 RX2_BANDSEL[2:0] RX2B_BANDSEL[1:0] RX2C_BANDSEL[1:0]
TRX-A < 450 01 10 101 XX 01
TRX-A 450 – 700 01 10 011 XX 11
TRX-A 700 – 1200 01 10 001 XX 10
TRX-A 1200 – 1800 01 10 000 01 XX
TRX-A 1800 – 2350 01 10 010 11 XX
TRX-A 2350 – 2600 01 10 100 10 XX
TRX-A 2600 – 6000 01 01 XXX XX XX
RX2-A 70 – 450 TT 01 101 XX 01
RX2-A 450 – 700 TT 01 011 XX 11
RX2-A 700 – 1200 TT 01 001 XX 10
RX2-A 1200 – 1800 TT 01 000 01 XX
RX2-A 1800 – 2350 TT 01 010 11 XX
RX2-A 2350 – 2600 TT 01 100 10 XX
RX2-A >= 2600 TT 10 XXX XX XX
Transmit
TX Port TX Filter (MHz) VCTXRX2_V1,V2 TX_ENABLE2A,2B TX_BANDSEL[2:0]
TRX-A < 117.7 10 01 111
TRX-A 117.7 – 178.2 10 01 110
TRX-A 178.2 – 284.3 10 01 101
TRX-A 284.3 – 453.7 10 01 100
TRX-A 453.7 – 723.8 10 01 011
TRX-A 723.8 – 1154.9 10 01 010
TRX-A 1154.9 – 1842.6 10 01 001
TRX-A 1842.6 – 2940.0 10 01 000
TRX-A >= 2940.0 11 10 XXX
Side B Filter and Antenna Switches
Receive
RX Port RX Filter (MHz) VCTXRX1_V1,V2 VCRX1_V1,V2 RX1_BANDSEL[2:0] RX1B_BANDSEL[1:0] RX1C_BANDSEL[1:0]
TRX-B < 450 10 01 100 XX 10
TRX-B 450 – 700 10 01 010 XX 11
TRX-B 700 – 1200 10 01 000 XX 01
TRX-B 1200 – 1800 10 01 001 10 XX
TRX-B 1800 – 2350 10 01 011 11 XX
TRX-B 2350 – 2600 10 01 101 01 XX
TRX-B 2600 – 6000 10 10 XXX XX XX
RX2-B 70 – 450 TT 10 100 XX 10
RX2-B 450 – 700 TT 10 010 XX 11
RX2-B 700 – 1200 TT 10 000 XX 01
RX2-B 1200 – 1800 TT 10 001 10 XX
RX2-B 1800 – 2350 TT 10 011 11 XX
RX2-B 2350 – 2600 TT 10 101 01 XX
RX2-B >= 2600 TT 01 XXX XX XX
Transmit
TX Port TX Filter (MHz) VCTXRX1_V1,V2 TX_ENABLE1A,1B TX1_BANDSEL[2:0]
TRX-B < 117.7 00 01 111
TRX-B 117.7 – 178.2 00 01 110
TRX-B 178.2 – 284.3 00 01 101
TRX-B 284.3 – 453.7 00 01 100
TRX-B 453.7 – 723.8 00 01 011
TRX-B 723.8 – 1154.9 00 01 010
TRX-B 1154.9 – 1842.6 00 01 001
TRX-B 1842.6 – 2940.0 00 01 000
TRX-B >= 2940.0 11 10 XXX
RF Performance
  • Power Output >10dBm
  • IIP3 (@ typ NF) -20dBm
  • Typical Noise Figure <8dB
Hardware Specifications
E310
  • Minimum version of UHD required: 3.8.0
  • Required version on the host computer must match what is running on the E310
E312
  • Minimum version of UHD required: 3.8.5
  • Required version on the host computer must match what is running on the E312
E313
  • Required version on the host computer must match what is running on the E313
Physical Specifications
Dimensions
E310
  • 133 x 68 x 26.4 mm
E312
  • 133 x 68.2 x 31.8 mm
E313
  • 186 x 280 x 106 mm
Environmental Specifications
  • E310 0-40 °C
  • E312 0-40 °C
  • E313 -40-71 °C
Operating Humidity Range
  • 10% to 90% non-condensing
E310
E310 Schematics
E310 DB
E310 Architecture
Key Component Datasheets
Motherboard
TXS02612RTWR SDIO PORT EXPANDER U23 (2)
XC7Z020-1CLG484CES9919 FPGA U11 (2,3,4,8,11,13)
Xilinx Zynq Product Page FPGA -
USB3340-EZK-TR ULPI Transceiver U33 (5)
AK4571VQP Audio CODEC U30 (6)
FT230XQ-R UART Interface U32 (6)
88E1512 Gigabit Ethernet Transceiver U13 (7)
24LC024/SN EEPROM U5 (9)
DS1339,SM Real-Time Clock U6 (9)
ADT7408 Temperature Sensor U8 (9)
MPU-9150 Motion Processing Unit U3 (9)
InvenSense MPU-9150 Product Page Motion Processing Unit U3 (9)
BMP180 Digital pressure sensor U4 (9)
BQ24192 Adapter Charger U1 (10)
TPS54478 Step-Down Switcher U20 (10)
MAX6510HAUT-T Temperature Switches U35 (10)
ATTINY88-MU Microcontroller U18 (10)
TPS61253YFF Step-Up Converter U19 (10)
AMY-6M GPS Module U12 (6)
Daughterboard
AD9361 Product Page 2 x 2 RF Agile Transceiver U8 (3)
24AA256 EEPROM U15 (2)
TC-1-43A+ RF Transformer T6 (3); T5 (3); T4 (3)
TC1-1-13M+ RF Transformer T7 (3); T10 (3); T1 (3)
TPS62140 Step-Down Converter U19 (4)
ADP1753ACPZ-R7 Linear Regulator U17 (4); U18 (4)
SGA-4563Z MMIC AMPLIFIER U12 (5); U4 (5)
SKY13418-485LF Antenna Switch U13 (5); U3 (5); U16 (5); U2 (5); U10 (6); U5 (6)
SKY13373-460LF SP3T Switch U11 (6); U9 (6); U6 (6); U7 (6); SW4 (7); SW1 (7)
MGA-81563 Amplifier U14 (5); U1 (5)
LFCN-5850+ Low Pass Filter FL32 (5); FL1 (5)
LFCN-2750+ Low Pass Filter FL37 (5); FL4 (5)
LFCN-2250+ Low Pass Filter FL23 (6); FL20 (6)
LFCN-1700+ Low Pass Filter FL40 (5); FL2 (5)
LFCN-1575+ Low Pass Filter FL25 (6); FL17 (6)
LFCN-1000+ Low Pass Filter FL33 (5); FL9 (5); FL27 (6); FL15 (6)
LFCN-575+ Low Pass Filter FL36 (5); FL5 (5)
LFCN-530+ Low Pass Filter FL29 (6); FL13 (6)
LFCN-400+ Low Pass Filter FL38 (5); FL3 (5); FL30 (6); FL11 (6)
LFCN-225 Low Pass Filter FL39 (5); FL6 (5)
LFCN-160+ Low Pass Filter FL34 (5); FL8 (5)
LFCN-80+ Low Pass Filter FL35 (5); FL7 (5)
HFCN-1600+ High Pass Filter FL22 (6); FL19 (6)
HFCN-1100+ High Pass Filter FL24 (6); FL16 (6)
HFCN-650+ High Pass Filter FL26 (6); FL14 (6)
HFCN-440+ High Pass Filter FL28 (6); FL12 (6)
BFCN-2435+ Bandpass Filter FL21 (6); FL18 (6)
FDG6301N Dual N-Channel, Digital FET Q8 (7); Q5 (7)
HSMS-8202 Mixer Diodes CR1 (7); CR2 (7); CR3 (7); CR4 (7)
LP5900TL Linear Regulator U25 (8)
ADP150AUJZ-3.0 Linear Regulator U22 (8)
AD5662RBJ 16-Bit nanoDAC U21 (8)
SN74AUP1T57 Voltage Translator U27 (8); U28 (8); U29 (8)
Request a detailed whitepaper covering features and components from [email protected]
Mechanical Information
Weight
E310
  • 375 g
E312
  • 446 g
E313
  • 1.8 kg
Drawings
E310
E312
E313
[ ADD DRAWINGS ]
FPGA
  • Utilization statistics are subject to change between UHD releases. This information is current as of UHD 3.9.4 and was taken directly from Xilinx Vivado 2014.4.
E310/E312/E313
1. Slice Logic
|          Site Type         |  Used | Available | Util% |
| Slice LUTs                 | 36203 |     53200 | 68.05 |
|   LUT as Logic             | 28108 |     53200 | 52.83 |
|   LUT as Memory            |  8095 |     17400 | 46.52 |
|     LUT as Distributed RAM |   870 |           |       |
|     LUT as Shift Register  |  7225 |           |       |
| Slice Registers            | 36562 |    106400 | 34.36 |
|   Register as Flip Flop    | 36562 |    106400 | 34.36 |
|   Register as Latch        |     0 |    106400 |  0.00 |
| F7 Muxes                   |   376 |     26600 |  1.41 |
| F8 Muxes                   |   125 |     13300 |  0.93 |
3. Memory
| Block RAM Tile    |   97 |       140 | 69.28 |
|   RAMB36/FIFO*    |   90 |       140 | 64.28 |
|     RAMB36E1 only |   90 |           |       |
|   RAMB18          |   14 |       280 |  5.00 |
|     RAMB18E1 only |   14 |           |       |
* Note: Each Block RAM Tile only has one FIFO logic available and therefore can accommodate only one FIFO36E1 or one FIFO18E1. However, if a FIFO18E1 occupies a Block RAM Tile, that tile can still accommodate a RAMB18E1
4. DSP
| DSPs           |  120 |       220 | 54.54 |
|   DSP48E1 only |  120 |           |       |
Interfaces and Connectivity
  • 10/100/1000 BASE-T Ethernet
  • Stereo audio out, mono mic in
  • Host USB support
  • 9-axis IMU
Front Panel
  • RF A Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on frontend side A
    • RX2 LED: Indicates that data is streaming on the RX2 channel on frontend side A
  • RF B Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on frontend B
    • RX2 LED: Indicates that data is streaming on the RX2 channel on frontend B
  • PWR: Power switch with integrated status LED, for status description see below.
  • SYNC: Input port for external PPS signal
  • AUDIO: Audio input / output
The status LED in the power switch indicates the power and charge status. It's behavior is firmware version dependent.
  • Version 1 (original E310)
    • Off: Indicates device is off and not charging
    • Solid Red: Indicates device is charging
    • Solid Green: Indicates device is on
    • Fast Blinking Red: Indicates an error code
      • 1 - Low voltage error
      • 2 - Regulator low voltage error
      • 3 - FPGA power error
      • 4 - DRAM power error
      • 5 - 1.8V rail power error
      • 6 - 3.3V rail power error
      • 7 - Daughterboard / TX power error
      • 9 - Temperature error
  • Version 2 (E312 and upgraded E310)
    • Slow Blinking Green: Indicates device is off and charging
    • Fast Blinking Green: Indicates device is on and charging
    • Solid Green: Indicates device is on (and not charging, if E312)
    • Solid Orange: Indicates device is on and discharging
    • Fast Blinking Orange: Indicates device is on, discharging, and charge is below 10% charge
      • 8 - Charger error
      • 9 - Charger temperature error
      • 10 - Battery low error
      • 11 - Fuel Gauge temperature error
      • 12 - Global (case) temperature error
Rear Panel
  • PWR: Locking connector (Kycon KLDHCX-0202-A-LT) for the USRP-E Series power supply
  • 1G ETH: RJ45 port for Ethernet interfaces
  • USB: USB 2.0 Port
  • SERIAL: Micro USB connection for serial uart console
GPIO
Pin Mapping
  • Pin 1: +3.3V
  • Pin 2: Reserved
  • Pin 3: Data[5]
  • Pin 4: Reserved
  • Pin 5: Data[4]
  • Pin 6: Data[0]
  • Pin 7: Data[3]
  • Pin 8: Data[1]
  • Pin 9: 0V
  • Pin 10: Data[2]
Audio
  • The E3x0 2.5 mm Audio Jack TRRS pins are assigned as follows: Tip=Mic, Ring1=Right, Ring2=Left, Sleeve=GND.
  • The Left/Right audio outputs are compatible with typical low-impedance headphones (16 to 32 Ohms). The Microphone pin provides approximately 2 mA bias at 2.2 V when not suspended. A variety of pin configurations can be found on commonly available headsets, so an adapter may be required.
Certificate of Volatility
E310
E312
SD Card Images
This folder linked above contains SD card images and the SDK (OE cross-compiler build environment) for the USRP E310 and E312. There is a manifest file that shows which packages, and which versions, are included in the OE build within each folder.
The "alpha", "beta", "e3xx-release-001", "e310-release-002", "e3xx-release-3" folders contain older versions which are currently obsolete. We do not suggest that customers use these files. These versions are no longer supported. They are provided here for archival purposes only.
The current version is Release 4, which located in the "e3xx-release-4" folder. We recommend the customers use this version. It is fine if you are already successfully using an older version, but at some point it is recommended that you upgrade to this current version so that you benefit from the latest bug fixes, new features, stability improvements, and other enhancements.
The Release 4 image includes UHD 3.9.2 and GNU Radio 3.7.9, and also includes the corresponding FPGA image file.
Note: An 8 GB SD card is required for the Release 4 image.
The SD card image contains both the FPGA image and the OS for the E310/E312. The FPGA images are located in the file system of the E310/E312 in the /usr/local/share/uhd/images folder.
There are two SD card image files for each version of the image, which include the text "-dev" and "-demo" in the filename. The "-dev" flavor lacks some graphical packages, such as X Windows and QT, which the "-demo" flavor includes. The two flavors are otherwise functionally equivalent, although the "-demo" flavor takes some additional space on the SD card and some additional memory to run.
The Release 4 image comes in two varieties. The variety that you will need depends on the product number of your E310 or E312, which is printed on the bottom of the device.
For the E310, the product number will be 156333X-01L, where X is a letter from A to Z. For devices where X is A, B, C, D, the images under the "ettus-e3xx-sg1" folder should be used. For devices where X is E or later, the images under the "ettus-e3xx-sg3" folder should be used. You must use the appropriate image for your specific device. The incorrect image will not work, and will only boot as far as the U-Boot boot loader before stopping.
For the E312, the product number will be 140605X-01L, where X is a letter from A to Z. The images under the "ettus-e3xx-sg3" folder should be used for all E312 devices.
You can burn the image to an SD card using either the "dd" or the "bmaptool" tool. Instructions on how to use these tools are at the links below.
The SD image files have an *.xz extension, as they are compressed using the LZMA/LZMA2 compression algorithms. You can uncompress these files with tools such as 7-Zip and the XZ Utils. Please see the links below for further information.
7-Zip
XZ Utils
The folder structure is listed below.
|-- alpha
|   |-- dizzy-test
|   |   |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.manifest
|   |   |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh
|   |   |-- sdimage-gnuradio-demo.direct.xz
|   |   `-- sdimage-gnuradio-dev.direct.xz
|   |-- fido-rfnoc-test
|   |   |-- sdimage-gnuradio-demo.direct.xz.md5
|   |   `-- sdimage-gnuradio-dev.direct.xz.md5
|   |-- fido-test
|   |   |-- ettus-e3xx-sg1
|   |   |-- ettus-e3xx-sg3
|   |   `-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh
|   `-- fosphor-testing
|       |-- fosphor.direct.xz
|       |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.host.manifest
|       |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.target.manifest
|-- beta
|   |-- dizzy-test
|   `-- dizzy-test-wifi
|-- e310-release-002
|   |-- sdimage-gnuradio-demo.direct.xz.md5sum
|   `-- sdimage-gnuradio-dev.direct.xz.md5sum
|-- e3xx-release-001
|   |-- e300-gnuradio-dev-image-release1.bz
|   `-- nodistro-eglibc-x86_64-gnuradio-dev-image-armv7ahf-vfp-neon-toolchain-nodistro.0.sh
|-- e3xx-release-3
`-- e3xx-release-4
    |-- ettus-e3xx-sg1
    |-- ettus-e3xx-sg3
Additional Resources
Downloads
FPGA Images
FPGA Images Read Me
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
USRP Embedded Series FAQ
General USRP E31x Questions
Q: What data rate is supported for continuous sample streaming to a desktop or laptop host-PC? A: Unlike host-based SDRs such as the USRP B, N, and X Series devices, the USRP E Series devices are not intended for continuous streaming of high bandwidth data to a desktop or laptop host-PC. The SDR application runs on an embedded CPU with limited processing capability. Users should leverage the FPGA using tools such as RFNoC to offload compute intensive algorithms that process high bandwidth samples.
Q: What data rate is supported between FPGA to the ARM processor? A: Due to the limited performance of the embedded processor, the maximum data rate from the FPGA to ARM cores is approximately 10 MS/s, and will vary with the processing load on the CPU. The AD9631 RFIC is capable of capturing 56 MHz of bandwidth. Processing signals at full bandwidth requires implementing algorithms on the FPGA.
Q: What is the purpose of the 1 GbE port? A: The E Series can run a DHCP client on the 1 GigE interface to enable connection to a larger network for remote access by another computer. Power over Ethernet is also supported on the E313.
USRP E313 Questions
Q: Which environmental tests were performed? A: The USRP E313 is tested against multiple environmental standards to ensure operation in outdoor conditions. These test include ingress protection, temperature, humidity, mechanical shock, random vibration, and altitude. Detailed specifications are provided in the [link data sheet].
Q: How do I protect external devices connected to the host USB port?
A: A circular conduit interface is provided in the kit. This component has large and small threaded ends. The small end connects to the USB port on the USRP E313. The user will need to connect their own waterproof structure to the large end to protect the USB device. Since requirements for external devices vary greatly, the conduit interface serves as a flexible starting point for users to build their own solution. See the Media:USRP E313 Dimension Pole Mount.pdf of the conduit interface for details.
Q: How do I protect unused ports? A: All ports come with protective end caps that should be left in place on unused ports.
Q: Why is a DC power supply not included? A: The RJ45 port supports Power over Ethernet and is intended as the primary power supply option. However, users can still use a DC power supply. Since requirements for supplying DC power in outdoor scenarios can vary greatly, a waterproof sleeve for the DC port is provided as a starting point for users to design their own solution. A waterproof sleeve for the RJ45 port is also provided.
Q: Do the RF inputs have lightning protection? A: The DC and PoE power inputs have surge and lightning protection, but the N-type RX/TX inputs and SMA GPS input do not. Users should design antenna lightning protection based on their application requirements.
